I've been thinking about a process that removes guesswork out of creating a good fitting galley door. I came up with the idea that I would rip some Sitka Spruce I have and can't use for my other project into 1/8" x 1.5" strips (Its a very light wood with long fibers that give it an incredible strength to weight ratio). Then with a 48" radius jig I should be able to consistently make top to bottom arching ribs by stacking up 12 laminations. I figure I could position 6 of them a foot apart for my 5 foot wide door. That would make such stiff ribs that the plywood shouldn't cause them to spring back and out of the 48" radius. Once I make the door, I can kinda make the rest of the trailer around the galley door to ensure a good fit. Even if there is slight springback, I can trace the profile of the ribs onto the sides to get a match. (I think I will go down another 1/4" on the sides so I can sandwich a soft rubber seal between the lid and the sides. I'm using System 3 T88 for glue because I've seen wingtip bows for antique airplane projects made with it and there is literally no springback and it holds it shape with a LOT of strength.
Has anybody done something like this? Anything I should be aware of? I think it'll look sharp and I can create channels in the ribs to hide wiring so it seems like a decent thought for several reasons.
Have the Kuffel Creek plans but using them only for general guidance.
All feedback appreciated.
Thanks
