Mechanical Door (Hatch) props
Those of you who used the Mechanical Door (Hatch) props from Austin hdwe. What size (length) did you use??
Thanks,
Geron
Thanks,
Geron
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
norm perkiss wrote:Geron,
I use this one. It is about 14+" closed and 27" when open.
http://www.austinhardware.com/product.a ... E96JHG9AMC
I proped the hatch up to the height that would clear my noggen and then located the prop on the side wall allowing for hatch ribs, cabinets, etc.
I mounted mine with the stock brackets. I have since talked to Uncle Denny, he modified the side wall bracket to fit almost flush. I will modify the bracket next time. It works perfect just not as slick an install as Denny.
