Painting trim
Painting trim
Postby Forrest747 » Wed Jun 20, 2012 3:30 pm
Ok I have been doing my research on Google and getting alot of conflicting advice on painting metal trim.
SOme say cant do it, others say power coat and i want an easy at home solution. just leaning toward scuffing it up and laying on rustoleum. am i far off.
the trim pieces will be used to hold the vinyl in place on the outside. will be using some butyl tape as well to help prevent water from getting under.
Forrest747
Cowbell Donating Member
Images: 447
Re: Painting trim
Postby 48Rob » Wed Jun 20, 2012 5:56 pm
Wash with soap and water first, then degreaser, then scuff/sand/etc.
Using primer is better than not using primer, Rustoleum will hold up reasonably well.
Moisture getting to the metal under the paint is/should be your concern.
Running screws through holes in the metal can remove paint, allowing moisture in.
After installing the screws, if you remove a couple at a time and inject sealant into the hole, then reinstall the screws, the screw hole, and metal edges will be protected from moisture.
Rob
48Rob
Re: Painting trim
Postby CARS » Thu Jun 21, 2012 11:23 am
Read the label before you buy your primer. Some primers are made for steel only, not aluminum. But you shouldn't have any problems finding aluminum primer.
All the rest of clean, scuff, clean, etc is spot on.
Chris'
Autobody
Restoration
Service
CARS
Re: Painting trim
Postby CarlLaFong » Thu Jun 21, 2012 2:48 pm
Zinc Chromate primer is what has been used for years on aluminum. If you've ever seen surplus aircraft parts, that green colored primer is ZC. There are also etching primers that will work well.
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Re: Painting trim
Postby Forrest747 » Thu Jun 21, 2012 2:56 pm
now for the stupid question. its flat stock 8 feet long and 1/4inch thick i am thinking of running it from my top galley hinge down the side wall so it will need to bend at a 1/2 inch radius is this possible i would assume best if i use a torch and pre form it.
91728
Forrest747
Images: 447
Re: Painting trim
Postby CarlLaFong » Thu Jun 21, 2012 5:26 pm
Aluminum should be cold bent. Heat will not make it softer like steel. Heat can be used to anneal the aluminum if it is too hard or becomes work hardened, If its the stuff from the BORG, it is soft and will bend easily
CarlLaFong
Images: 5
