webbaldo wrote:Thanks for the advice, when you say sheathing, do you mean 1/4 ply or something else?
Yes, 1/4" ply ... some folks use luan, some birch, some just common fir plywood ... "sheathing" is just a general term for what ever covers the framework.
Also my original plan to try and make the whole thing waterproof as possible was to cover everything in epoxy as well as using it for glue.
Instead, would using titebond glue, then polyurethane for waterproofing be a good (and cheaper) alternative? I want it well built but trying to keep costs down.
Or is there no cheap way to do it? Am I better using titebond to glue it all, then use Epoxy to seal the finished 'sandwich'?
I'm not a good one to ask about that ...
... as I, personally, don't agree with completely encapsulating the wood in a trailer (completely sealing everything, whether it is varnish, polyurethane, epoxy, or what ever). My take is that wood's inherit nature is to absorb ambient moisture and then dispel it in its own good way ... when you completely seal the wood, you prevent this from happening, and if you ever compromise the seal (whether from a scratch or other slight damage), you give moisture a way to get in but not out, and thereby give way to the beginnings of wood rot. Waterproof the outside, but give the wood the ability to "breath" on the inside. Others' opinions will vary ... it's been a long-standing debate among the wooden boat crowd ...
My other worry is that I was gonna use contact adhesive or 3m 4200 to glue the aluminium on. If I epoxy the wood underneath, will the adhesive still work?
Yes, the adhesive will still work ... but make sure it is a "soft-setting" adhesive like Rubber Roof Cement, Vinyl Top Adhesive, or the like (common contact cement is a "hard-setting" glue, and will not allow the aluminum to expand & contract very much without either delaminating the cement bond or the glue holding the plywood together) ... and I
always recommend "floating" the roof & hatch skins.
Continued Good Luck, and as always ...
CHEERS!
