Floor framing 1x6/1/2 ply
Postby webbaldo » Sat Jul 14, 2012 11:54 am
If I use a sandwich of 1x6's for my floor frame with 1/2 plywood top would this give me enough meat to screw my sides to? (ie just the inch in the middle for screws)
Should I put a couple of bolts through the trailer frame and walls (2 per side) for good measure?
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Re: Floor framing 1x6/1/2 ply
Postby Forrest747 » Sat Jul 14, 2012 6:51 pm
The half inch floor is thick enough. That is what I put down. Also for bolts yes two should be fine on each side. I did 5 5/16 on each side and then two on the front and rear. A lot of over kill but at the time I didn't have the knowledge I have now. With the amount of bolts ur planning you should withstand around 800mph before u have issues.
Forrest747
Cowbell Donating Member
Images: 447
Postby aggie79 » Sun Jul 15, 2012 7:58 am
Actually a 1x2 should be sufficient.
Postby webbaldo » Sun Jul 15, 2012 10:31 am
aggie79 wrote:Actually a 1x2 should be sufficient.
so with 1 inch being the side the wall will be screwed to, this would be thick enough? just dont want screws splitting the 1 inch wood
webbaldo
Postby CarlLaFong » Sun Jul 15, 2012 11:37 am
If you're concerned with splitting, pre drill the screw holes.
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby aggie79 » Sun Jul 15, 2012 4:28 pm
My walls are glued and screwed into my floor which is 1x2 "flat" and 1/4" plywood top and bottom. I did pre-drill the holes in the wall before I stood it up, and pre-drilled the holes in the floor edge after the walls were stood up.
Another technique I saw - from Madjack - was to tie the walls and floor together using continuous aluminum angle along the length of the floor. (I think he used 1" x 1" x 1/16" or 3/4" x 3/4" x 1/16".) He drilled holes in each leg of the aluminum for screws into the wall and floor.
