Haven't been there nor done that, but from what I have read some guys will bend the ply a little at a time to "train" it to behave properly. Then once the curve is pretty close, then they glue and screw.
Have also read of plenty of times when nails or staples pull back out, so screws are what is recommended.
Fasten the bottom edge with screws only and use ratchet straps to pull the ply up short of hearing pops or cracks. Use bar clamps with wedges across the front if needed to push the ply up against your spars and ribs. Come back the next day and crank down on the straps a bit. Repeat until the ply has taken the form of the front curve. It will likely spring back when released, but should have enough curve in it so that it does not break when you glue and screw it back down.
Lots of people report success using wet towels, or hot wet towels to help soften the wood, but I would only try that as a last resort and only if using exterior or marine grade ply. Not only concerns me for delaminating problems with interior grade plys, but also raising the grain and creating checking/splintering, especially if doing a woodie or paint).
It's just what I have read and makes the most sense to me. Good luck!
