if you have pics or ideas then show/tell me
aluminium tubing 1"...2" one or two tubes curved or straigt or .... ?
Nobody wrote:After 'finishing' construction we used our TD for several months before I decided to add 'fenders' & the bumper - more for looks than any other reason...
I ordered a 'diamond plate' trailer fender from Northern Tool & modified it to fabricate 2 'mini' fenders to minimize the 'raw' look of the cut-outs at the wheel wells. I found a new 'diamond plate' tailgate protector for an older Chevy P/U, fabricated a bumper 'base' from a couple of lengths of 7/8" square steel tubing, 'wrapped' the diamond plate around that & fastened it to the TD chassis with heavy steel strap. Since it was primarily for cosmetic reasons I didn't expect much protection from severe impacts -
Although I didn't expect much (if any) impact protection from the 'bumper', when I was rear-ended Labor Day weekend of 2010, the collision pushed the bumper down (bending the mounting straps). My TD sustained considerable damage to the lower part of the galley hatch & to the trailer chassis but I'm pretty sure the 'light duty' bumper somehow aided in deflecting much of the force of the impact away from the 'body' of the TD. I was able to repair the damage & fabricate new mounting straps for the bumper & the TD is now 'good as new', with little evidence of the collision damage.
Because of the profile of our TD the bumper doesn't intrude into 'knee space' when using the galley, & even tho designed for looks it does provide a modicum of protection from impact. Just a small example of 're-purposing' (the Chevy tailgate protector) & doing it our way. Won't suit everyone but you may pick up some ideas...
legojenn wrote:- - -
How wide is your trailer? I am hoping that my first build will be a 5' trailer that sits nicely on a 4' frame. According to the specifications on the Harbor Freight site for their 4' trailers, the total width is 61-1/4. I'm trying to figure out a way to not go over 5' wide and not build walls that will rub against my tires.
