Page 1 of 1
Where to find 1/8 inch Baltic Birch
Posted:
Thu Aug 09, 2012 11:32 am
by stu_stumble
Hello all. I am trying to locate some 1/8 Baltic Birch. I live around Norfolk NE. I have checked with local lumber yards and they do not have this stuff. Only have 5 MM Luann which from reading the forums is not good to use at all for skinning the exterior of my camper. I would be able to drive to Omaha NE if Necessary. Can anyone tell me where I might be able to locate some of this in Nebraska. Would Lowes or Home Depot carry this. If I cant find this what would be suitable to use for skinning my roof otherwise. I am building a Rimple design with 24 inch radius on front and back. Like I said I can find plenty of Mahogany Luann but I am not sure this will work. I plan on coating everything with CPES. Thanks fro the help in advance.
Re: Where to find 1/8 inch Baltic Birch
Posted:
Thu Aug 09, 2012 11:35 am
by NathanL
Cabinet shops and speciality wood stores. They may be hard to find but normally every region has a cabninet shop or store that sells wood to the other cabinet shops. Might call one nearby and ask them where they buy their wood after you explain what you are doing.
This is a handy reference as well.
http://www.woodfinder.com/http://www.glen-l.com/resources/lumber-suppliers.htmlIf you just can't find it anywhere locally you can always order it from several places online for a shipping charge of about $100-$125. Another option if you can't find 1/8" bitch is 1/8" and 3/16" Okoume marine plywood which will cost more but will bend just as easly and uses a waterproof glue. If you are painting it or covering it - it will work well. If you are going fo the natural look it will look good as well but not the same appearance as birch. Just pointing that out if by some chance some place has that instead of the birch.
Posted:
Thu Aug 09, 2012 10:49 pm
by Wolffarmer
There are at least 2 lumber yards around here that has it. I guess NE is special.
Randy
Posted:
Fri Aug 10, 2012 8:22 am
by Forrest747
In Denver there is National Wood products,
4747 Ivy Street
Denver, CO
80216
Telephone: (303) 293-8660
Toll Free: (800) 428-4712
Fax: (303) 293-2275
They are here in Salt Lake as well. Very good product, not sure what part of NE your in. JUst a suggestion
Posted:
Fri Aug 10, 2012 10:48 am
by Hillmann
If you go to a lumber yard, not lowes or home depot,but a real lumberyard, and tell them what you need they will be able to get it for you. They only problem you may run into is they may have a minimum order. For my local yard they wanted me to order 5 sheats
Posted:
Fri Aug 10, 2012 3:17 pm
by planovet
NathanL wrote:Cabinet shops and specialty wood stores.
This
Posted:
Wed Aug 15, 2012 7:35 pm
by real550A
Check with privately owned lumberyards. I found it at the first two I called this week.
Posted:
Wed Aug 15, 2012 7:36 pm
by bdosborn
Austin Hardwoods
975 W Mississippi Ave.
Denver, Co 80223
http://www.austinhardwoods.com/home.shtml
Posted:
Thu Aug 16, 2012 7:39 pm
by GerryS
Our Menards had it...
Posted:
Thu Aug 16, 2012 7:56 pm
by real550A
I asked at the local Menards lumber desk. The guy looked through a bunch of his supplier books and sent me
to some other lumberyards. Anyway, I'm picking up two sheets tomorrow morning. Going with 3 lam 1/8" Baltic Birch for
the inside of the galley door, and two lam 1/8" Bending Birch for the outside, which will also be covered by aluminum skin.
