Bending Roof Skin?????
I know there are other threads on this and I have read them. I am new at this and want to make sure I am getting this all right.
Can you bend 1/4 (5.2 mm) Luan plywood for rook skins. I will have 24" radius on front and back as I will be building the Rimple design trailer. Can I make these bends without much hassle like having to steam the wood or wet it, or will they break.
Should I use 1/8 Baltic Birch instead? If I do this will one layer of this be sufficient or would I need to double layer it. I will just be sealing and painting, no aluminum.
Also, do I bend the plywood I get be it 1/4 luann or 1/8 baltic lengthwise(over the 8 foot length) or on the short size( The 4 foot length)?
I appreciate all of the help with this from all of you.
