Why you want sliding cabinet doors!!
Postby CliffinGA » Sat Aug 18, 2012 5:51 pm
Today was a great day until catastrophe struck, while finishing up the wiring on the tear, I had the hatch (unfinished) propped open and the cabinet door open on one side. Well you guessed it, the prop fell, hatch closed, corner of the said door is now sticking out of the dang hatch :x . Well if I had followed the plans this would not of happened as Mike has sliding doors on there. Just goes to show that sometimes when you make changes you do not always think all things thru.
Cliff :thumbdown: :thumbdown:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Re: Why you want sliding cabinet doors!!
Postby Shadow Catcher » Sat Aug 18, 2012 6:07 pm
Bummer
Or you hinge the doors from above.
Postby LDK » Sat Aug 18, 2012 6:30 pm
Hey Cliff
What bad luck, I feel for ya man. :( Is there any way you can patch the hole or are you gonna build another hatch?
LDK
Postby doug hodder » Sat Aug 18, 2012 6:42 pm
Sorry to hear of your incident Cliff. Not that it matters now, prior to the galley being finished I always clamp a support stick to the trailer wall so that it can't get knocked out and allow the hatch to drop. Like mentioned, you can always hinge them on the top.
On the other hand....I have sliders in the Nomad running front to back. The drawback to them is that if you don't put some sort of locking system to keep the doors from sliding, then can slide and unload the cabinet in the galley while towing. I use a stick with a notch on each end to hold the doors at the handle. Also...once you remove that stick, sometimes you have to go though one side to move the stuff that may have shifted in towing and is blocking the other slider from moving. Just my experience, others may vary. They won't however, punch a hole in the hatch. Doug
Postby jeff0520 » Sat Aug 18, 2012 8:20 pm
Bummer! sorry to hear about the incident! Hope the repair goes smoothly
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby CliffinGA » Sat Aug 18, 2012 9:03 pm
Thanks guys,here is the pic
and I will take that part of skin off tomorrow and reglue another, since my tear is 5' 7" I have a seam on the hatch and you can see the seam below where I had started filling in the seam before taping and epoxying! I will also be flipping the hinges to the top also. After redoing the hatch 5 times and reskinning twice for different issues, I had one that was great and was going in beautifully and then Murphy caught up to me!
Doug I figured that there is draw backs to all door styles and how they're mounted in the galley,I just never realized how unbelievably destructive this one was. I'm also figuring out a "Cliff" (idiot) proof hatch support to help avoid this again.
Yes I even had to laugh at my own idiocy after it happened.
Cliff :D
My Build:
CliffinGA
Images: 207
Postby Oldragbaggers » Sat Aug 18, 2012 10:14 pm
I am so sorry Cliff. I know how hard you have worked to achieve a good hatch and this must be so disappointing. I hope the reskinning goes well and you've got it back on there in no time.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby nevadatear » Sun Aug 19, 2012 12:33 am
Could be worse. We took ours camping before we had the hatch supports in place and were using the stick method, unsecured. Hatch fell hitting me on top of the head. I am sure I had a concussion as I had a headache for weeks.
nevadatear
Images: 171
Postby starleen2 » Sun Aug 19, 2012 1:21 am
CliffinGA wrote:Image
Cliff :D
Ouch
nevadatear wrote:Could be worse. We took ous camping be for we had the hatch supports in place and were using the stick method, unsecured. Hatch feel hitting me on top of the head. I am sure I had a concussion as I had a headache for weeks.
Oucheeee!
starleen2
5th Teardrop Club
Postby CliffinGA » Sun Aug 19, 2012 5:24 am
Oucheeee!
+1 Debbie
My Build:
CliffinGA
Images: 207
Postby pohukai » Sun Aug 19, 2012 10:38 am
OUCH! But as a friend once told me, this is the time that tests the true craftsman; the art of recovery. Based on what I''ve seen, you'll ace this without any problem. :thumbsup:
pohukai
Images: 9
Postby les45 » Sun Aug 19, 2012 1:04 pm
Hang in there, Cliff. Just remember the words of that famous philosopher, Kelly Clarkson, "What doesn't kill you makes you stronger".
les45
Images: 605
Postby Oldragbaggers » Sun Aug 19, 2012 1:39 pm
Sometimes what doesn't kill you really pisses you off. This would have REALLY pissed me off. :lol:
Becky
Oldragbaggers
Images: 331
Postby DMcCam » Mon Aug 20, 2012 9:04 am
Bummer Cliff, ouch is right! I have a feeling you'll patch this up in no time sir disappointing as it is. I think at this point in my build I'd probably laugh too.
Dave
DMcCam
Postby CliffinGA » Mon Aug 20, 2012 6:48 pm
Thanks all! Last night pulled the damaged skin off and recut a new piece and glued and screwed it down in place. Today came home and got it unscrewed and routed it all down to fit the sides and reattached the hinge after I started sanding the hols and stared outtying the gaps. Besides this my new doors have hinges at the top and it is so much better that I swaapped them to open up and not to the sides. Only issue was the orbital sander died tonight after a sailboat, 2 tears and many other projects.
Cliff :thumbsup:
My Build:
CliffinGA
Images: 207
