Bow fronted Teardrop?
Postby hankyknot » Thu Aug 23, 2012 5:36 pm
Not sure of the technical term but are there any plans on here for a teardrop who's front has kinda been turned on its side so the curve runs left to right rather than up and down?
I'm thinking it would give a little more usable space in the bow
hankyknot
Re: Bow fronted Teardrop?
Postby Lgboro » Thu Aug 23, 2012 9:56 pm
You can find a few in the Hall of Fame that are built the way you described.
Lgboro
Images: 53
Postby hankyknot » Thu Aug 23, 2012 10:06 pm
Thanks lgboro, I only thought to look in the plans section, still finding my way around.
hankyknot
Postby mezmo » Thu Aug 23, 2012 10:44 pm
Camp-Inn builds a model 560 with that design:
http://tinycamper.com/teardropmodels.htm
Member Irmo Atomics is building a take-off on the 1930s
Airstream Torpedo with that design feature:
viewtopic.php?f=50&t=51954
A couple others have also done that design feature if I'm
recalling correctly, maybe you'll run across them somehow.
Oh, 'just remembered grant whipp is using the feature on his
build [pg4]:
viewtopic.php?f=50&t=44462&start=45
Here's another recent build journal with it: The Finley T-1:
viewtopic.php?f=50&t=51053
Norm/mezmo
mezmo
Images: 194
Postby angib » Sat Aug 25, 2012 9:41 am
If you are tempted to combine a round front with a roofline that dips a little, or a lot, to the front, bear in mind that will give you compound angles at the end of any roof beams and a non-square joint between the sides/front and roof. No big problem if you have great woodworking skills and/or a decent set of hand tools but it's one more thing to think about.
And sadly I think the dipping roofline looks really good with a round front, as on this early Airstream trailer:
95486
angib
5000 Club
5000 Club
Images: 231
Postby Irmo Atomics » Sun Aug 26, 2012 4:00 am
Here's an example of what anjib was referring to
97290
A compound miter saw, trial and error, lots of extra material, and patience will go a long way to achieving a sloping curve.
A band saw was used to get the angle on the top plate.
Bob
Irmo Atomics
Images: 64
Postby eamarquardt » Sun Aug 26, 2012 4:37 am
More space in the "bow". Is your teardrop gonna be amphibious? :thinking: Just askin. :lol: Will it have bulkheads or walls. Doors or hatches. A ceiling or overhead. A bathroom or head? A floor or deck? Will it be cutter rigged, sloop rigged, ketch, or yawl? "Enquiring minds want to know" (Google this phrase).
Gus
eamarquardt
Images: 150
Postby hankyknot » Sun Aug 26, 2012 7:50 am
eamarquardt wrote:More space in the "bow". Is your teardrop gonna be amphibious? :thinking: Just askin. :lol: Will it have bulkheads or walls. Doors or hatches. A ceiling or overhead. A bathroom or head? A floor or deck? Will it be cutter rigged, sloop rigged, ketch, or yawl? "Enquiring minds want to know" (Google this phrase).
Gus
Do you ask this question of every teardrop builder that has a galley?
Think bow as in curved, not bow as in the opposite of stern but either works.
hankyknot
Postby eamarquardt » Sun Aug 26, 2012 8:07 am
Gus
Nope, I only ask if the trailer is being planned with a bow. Can I think of the front of the trailer as the stem? I don't like to be contrary and think of opposites. If it had a leading edge I might ask if was gonna be wing shaped.
Gus
eamarquardt
Images: 150
Postby Deryk the Pirate » Sun Aug 26, 2012 6:13 pm
lol I live in a sailboat, and when I saw "bow" I immediatly thought like "bow top" like some gypsy vardo's lol
deryk
Deryk the Pirate
Images: 158
Postby rowerwet » Sat Sep 15, 2012 10:08 am
a "raindrop" is how most refer to it here, also a paddle head (think of the radius on the end of a wooden canoe paddle) would be a sort of flattened raindrop, the curved roof line would be even nicer. My next trailer will be a raindrop as I think it does offer a lot more room for storage/living compared to a tongue box that doesn't add as much storage, and no living space. Camp Inn makes it into a nice bunk for kids/pets.
rowerwet
Images: 521
