Below is a quick sketch of how I plan to construct/attach my floor/walls with a description below it and questions at the bottom.
The trailer current has 3 metal risers on each side that I'm planning to cut within 1 1/2 inches of flush then fold over and use as mounting tabs that will carry a bolt through both sheets and plywood and the 2x3 skirt (bolt not shown in the diagram).
Elsewhere the plywood would be glued and screwed to the skirt every 6-8 inches.
I plan to build a stick frame wall to which the side walls would be glued and screwed that will allow me to insulate the walls. An internal (t&g perhaps) wall would be installed to cover the insulation.
Stabilising jack mounts would be bolted to the frame through both subfloor and underside sheeting with all holes being filled with silicone once everthing was bolted in place.
Finally some floating floor would be used to floor the interior of the trailer.
I have two questions;
1.) Is there anything wrong with what I'm planning?
2.) I'm assuming it would be a good idea to include a vapour barrier somewhere in there although I'm never sure whereabouts it would need to go. Between the trailer frame and subfloor, or between the trailer frame and underside, same with the sidewalls, outside the frame and insulation, or inside?
Thanks in advance for all your help, rainy days like today gives me too much time to think so I'm sure I'll have more questions shortly.
