by meledward » Mon Sep 17, 2012 11:30 am
I have only just started using Roxul.
I did a fair amount of research on it before using it. I came to knowing it when I was looking at building a walk in refrigerator (basically a southern root cellar) for my garden.
It has significant advantages over fiberglass. 1) its not fiberglass!
2) Working with it is a dream. I used it to insulate my pantry that I built (62 degree thermo controlled pantry) and I stuffed it between the sloped ceiling joists. Just stick it in there and it holds in place, no need to secure it. I had a 20" OC opening in that slant ceiling (completely no structural as it is merely dressing up an existing angle I didnt like). For that opening I turned the insulation sideways cut it and once again it just sits in the opening. Fibereglass would have been hell to work with.
3) if it gets wet, it doesnt collapse like fiberglass insulation and it still retains its R-factor
4) this stuff is dense, which allows #2 and #3. Its like working with a pocket lint. I mean you know that pocket lint that is really dense, but will crumble if you break it up. This is like a tightly packed loose foam. if you use a good knife you can easily cut it to size. If you man-handle it you can smash it and crumble it some, but it still more or less retains shape and form. Very easy to work with for non-stnadard locations. Its a beatuy for that 6" OC stud etc.
5) its a sound deadner.
Now, is it better than the "pink" and "blue" foam?
Foam advantages - it is a vapor barrier. If you install the foam, and caulk and or foam seal all the tiniest of gaps (and even better overlap the foam instead of using one 4" thick, using two 2" thick in opposite running directions you can get an air tight seal. Well, In campers you probably want to "breathe" some, same as a house. To tight and you create new issues. For my Cooler/Fridge this is a big benefit.
And as shown above, foam has better values R per inch.
Well, that is everything I know, hope it helps.
