Now what could this be for...
Postby bg » Sat Oct 01, 2005 2:35 pm
Now what could 60' of 2" angle be used for?
Hmmm, Maybe the frame for a tear?
That's about all I have so far, broke the sawblade. Didn't have a spare.
My inspector showed some interest though...
It'll be a couple of weeks before I get a finished frame...
Bobby(, Kim & Wayne)
bg
Postby Guest » Sat Oct 01, 2005 3:32 pm
bg,
It won't be long before your build is further along than mine, I'm sure...
Your inspector looks like a good little buddy!
Guest
Postby davel » Sat Oct 01, 2005 3:48 pm
BG,
That looks like the beginning of a trailer to me!! :applause: :applause: :applause: :thumbsup:
davel
Images: 32
Postby SteveH » Sat Oct 01, 2005 4:32 pm
2" ANGLE! Now everyone knows that won't work! You must use no less than 2" X 1/8" square tubing. Anything less is just too weak. :)
SteveH
SteveH
Images: 42
Postby bg » Sat Oct 01, 2005 4:50 pm
:rofl: That's 192 pounds of steel.... lol Less than half of that will be in the final trailer.
My utility Trailer is built from 2x3x3/16" angle, The finished 5x10 trailer weighs just under 500lbs...
bg
Postby mikeschn » Sat Oct 01, 2005 5:05 pm
bg,
that's an interesting base... are you concerned that your mattress is going to get wet?
Postby bg » Sat Oct 01, 2005 5:26 pm
mikeschn wrote:bg,
That's my utility trailer...
bg
Postby Ron » Sat Oct 01, 2005 8:13 pm
Nice trailer bg, it looks like you really know what your doing.
Ron
Ron
Images: 64
Postby bg » Sat Oct 01, 2005 8:27 pm
Ron wrote:Nice trailer bg, it looks like you really know what your doing.
Ron
I learned ALOT building that thing... one of those being that you cannot own too many vice grip clamps. You have no idea how happy I was the first time i hooked that thing up and it pulled straight.
By no means am I a weldor. Pretty much a jack of all trades type. If anyone in the DFW area needs a relatively simple frame welded up, I'm game.
This is my frame design, Really simple and lightweight, credit goes to angib for the 8' Jim Dandy design
bg
Postby Joanne » Sat Oct 01, 2005 10:08 pm
Ron
In the drawing it looks like you are going to have a removable tongue. I have a removable tongue on mine, so I have two points you may want to consider if you are planning one too.
Here's a photo that will help explain.
You may want to have the receiver tube protrude a little ways beyond the front crossmember of the trailer. (Mine sticks way out to support the tongue box)
First, this will allow you to pull the pin and remove the tongue without having to reach (or crawl) under the trailer to get to it.
Second, you want somewhere to attach your tongue jack even when your tongue is removed. I missed the second point when I built mine and now I have to lower the front leveling jacks before I can remove the tongue. Not a big deal, but I it's obvious that I didn't think things through as well as I should have.
Anyway, that's just my .02 worth!
Joanne
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby bledsoe3 » Sat Oct 01, 2005 10:55 pm
Joanne, I had the same issue. This is what I did.
Image[/img]
If your channel is long enough you could do the same thing. Jim
bledsoe3
Images: 112
Postby bg » Sun Oct 02, 2005 7:31 am
The jury's still out on the removable tongue idea. Might just make a simple a-frame tongue again.
bg
Postby WarPony » Sun Oct 02, 2005 8:10 am
2" angle will never work........................ just drop that stuff off at my house and I'll get rid of it for you :lol: :twisted: !!
WarPony
Images: 289
Postby Ron » Sun Oct 02, 2005 9:50 am
Bledsoe3,
In the picture of your trailer there are metal "tabs"? attached to the frame. What are these for? Are they flat peices of metal or angle iron welded on? Just wondering because I need to design a frame for mine and I'm always looking for those little "Extra" Things I can do to make things better. Thanks
Ron
Ron
Images: 64
Postby SteveH » Sun Oct 02, 2005 11:14 am
bg,
I hope you know my comments about the angle iron were just yank'n your chain. :) I was being facetious because lots of people on here insinuated that angle iron wouldn't work for a frame when I was building mine, but it seems to be just fine. Oh, and it seems to be just fine for the CampInn also. ;)
SteveH
SteveH
Images: 42
