fcreamer88 wrote:So I need true Baltic birch....not just birch plywood? I planned on insulating the roof, but wasn't too concerned about te walls. Since you reminded me about the moisture blocking, I might oughtta think about it. Especially since the whole purpose of building an off road td is so I can camp on the beach.....humidity central! If I go with sad wish style walls, do y'all recommend using thick ply inside and routing out spaces for the insulation then sheeting over that? What about framing out the walls with, say 1x1's. Then using thin ply inside.
I've seen the sandwich walls done both ways and both ways work equally well. I did mine with the 3/4" ply. I think it's heavier than a frame made from 1x2's but it was the right thing for my skill level. I didn't feel like I had the skills to build the dimensional lumber wooden frame when I first started. I could probably do it now. The one advantage I see with the dimensional lumber is that it is true 3/4" thickness so your insulation will fit perfectly. But a few minutes with a belt sander took my rigid foam insulation down to the same thickness as my plywood without too much trouble. If you use the white styrofoam insulation that has the foil sheeting on it, it will compress easily enough into the spaces. I wanted rigid foam for additional strength in the sidewalls.
I don't think there is a right or wrong answer to this question. (As is the case with most things concerning teardrops!!) It's all up to you, what you feel comfortable with, what works with your design, what will get you where you want to go weight wise, what fits into your time schedule and budget (I think skeletonizing the plywood would be faster, not sure how it compares cost wise).
There are so many of these types of decisions to make right at the beginning, and looking at all the beautiful, skilled, creative and some very complex builds on this site can leave you overwhelmed. I remember agonizing and bugging people about each and every detail ad nauseum. I felt that somehow if I wasn't incorporating all these techniques and ideas I was seeing I was somehow not going to be building it right, or it would be looked down upon as being "crude." But even after the analysis and research I put into it I find there are many things I would do differently if I could do it over.
So, +1 what Ira said, for the most part.I wish for my first build I had taken the fastest, easiest, cheapest route possible to doing everything, without sacrificing structural integrity, utility or a nice appearance. (This is the one place I depart from Ira's wisdom. I would insulate my floor and roof, but my walls would be 3/4" ply, period.) Just get that inital learning experience, then get out camping and live with it for awhile and learn what I really want and need in a trailer. Then if I found out it wasn't my forever love I wouldn't feel so badly about passing it on and building the next one. If this is your first build, I would encourage you to keep it very simple.
As always, the usual disclaimer, "
other's opinions will most certainly vary."
