MY TRAILER FRAME DESIGN
G'day guys
This is the drawing of my trailer frame showing all the details of the layout. All going well, I will begin building it next week. The dimensions are in millimeters but the length is 120 inches (10 feet) and its 60 inches wide (5 feet). The walls of the cab will be fitted to the outside of the frame to keep the full 60 inch width inside. The "A" frame is not shown as I will add that on after the basic frame is constructed. The top of the frame will have 2 3/4" x 1 1/2" pine bearers bolted to it and the 1/2" ply floor will be screwed to the bearers. The 2 3/4" wide pine bearers sound like overkill but you will see why I am using these when I begin to post the pictures of the build in the build section. The cab will be bolted to the bearers through the sides and will overlap the frame down to the bottom of the RHS. I will be using 1/4 NF-28 tpi bolts but would much prefer 1/4 BSF -26 tpi. At least I can still buy !mperial bolts here, ( I hate the metric system with passion!). There are no dramas using 1/4" dia. bolts as the core strength is still far greater than threads cut with a die. The bolts made by a manufacturer have rolled threads and in a high quality bolt, the minor diameter still has ample strength. All the bolt hole will be drilled first before welding and transferring the holes to the floor ply will then be an easy task. Before I weld all the parts of the frame together, I will slip a 1/4 bolt into a piece of RHS and see how much load I can apply before the bolt snaps or the bolt has pulled completely through the timber bearer. I really don't want to go up to 5/16" bolts unless it's absolutely essential. Six of the 1/4" bolts will go through the 1/2" floor for extra strength and integrity.
All the open ends of the RHS will be covered by welding an inside fitted plate and the finished frame will be given two coats of Cold Galvanizing paint. The finished colour will be red. The springs are mounted on a short length of 2" x 2" x 1/8 RHS as the 1 3/8 wide RHS is not wide enough to support them.
The drawing for the side view and section of the cab is almost complete and I will post that also to show you what I am building. Any comments are welcome.
Kody
Kody
