by Oldragbaggers » Fri Oct 05, 2012 6:38 am
I personally would not be comfortable using only varnish. Varnish, exposed to moisture and UV, can and will at some point, start to flake up enough for water to get under it. Anyone who has ever owned a boat with a lot of exterior wood can confirm what I am saying. After a year or so you will start to see dark spots on your wood under the varnish where tiny hairline fissures have allowed water to get under the varnish and start to darken the wood. If we are talking about the hardwoods used on the exterior of a boat it's not that big a deal. You sand it down, revarnish and you're back in business for a couple of years (although most people sand and varnish yearly to prevent this from happening). If you're talking about plywood, especially if it isn't a good exterior grade of ply with waterproof glues, you could be talking about delamination.
A lot of people use CPES alone, others use epoxy resin alone, others use both, some lay up cloth. Me, I am certifiable and have used all of these, not all together, but different methods on different portions of the build. I would say that if your teardrop is going to be garaged or kept out of the elements, and if you plan to be diligent with the upkeep of your varnish and performing regular inspections for leaks, you probably can skip the epoxy sealer, but I should think the peace of mind would be well worth the extra step, and especially on the edges of the plywood which will absorb any water that finds its way there like a sponge. (Did you see the delamination on Mike Schneider's Baja Benroy.....YIKES!!!)
At the very least, if you decide to go with only varnish, I would apply a couple of coats of varnish that have been thinned so that it will soak deep into the wood and seal it as much as possible before applying the surface coats.
Just my 2 cents, and probably worth about that.
