Paint on epoxy resin advice needed.
Postby toddallman » Sun Sep 30, 2012 8:25 pm
I am just about at the stage where I will be applying the Epoxy Resin and fiberglass tape on my TD. I need advice from all of those who have skinned with paint. I was wonder what kind of primer and paint people have used. I am aware that many used boat or automotive paint but has anyone used paints from other sources such as the big box stores? I would like to save on money because the funds have run low on my project. I need to try to get this project complete and out of my dads garage soon. He would like to park his new truck someday soon. :lol:
toddallman
Re: Paint on epoxy resin advice needed.
Postby Oldragbaggers » Sun Sep 30, 2012 8:52 pm
I used Rustoleum Clean Metal Primer and Gloss Protective Paint on the inside of my tear, which was also epoxy sealed. I think Zach used the same thing on the exterior of his teardrop the X-II. Planovet used Tractor and Implement paint I think.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby CliffinGA » Sun Sep 30, 2012 9:09 pm
I used Valspar Tractor and farm implement also but TSC no longer carry's it so will probably go with an auto paint in a couple of years.
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby working on it » Sun Sep 30, 2012 9:52 pm
In regards to Tractor Supply Valspar Tractor and Implement paint versus the new TSC Majic Tractor,Truck and Implement paint. I also used the Valspar on my exterior. I was well pleased with the results, though I painted in 105-110 temps and used NO hardener for two reasons: the high temperatures would've caused too rapid drying (I didn't want it to crack), or pull apart from the polyurethane I was overcoating (I let it cure for a week between coats, the same with the poly). I used the TSC Valspar because it was chemically similar to the polyurethane (both had urethane resin as part bases). The TSC Majic brand replacement paint should be OK for interiors, and in most exterior colors (some are reported to fade in sunlight) and it reportedly dries slower (needs hardener). Its' alkd resin base is soy-based, according to some, and won't be quite the same as the older Valspar. I wish I had bought more of the old stuff; I fortunately have some left for future use.
173193172890148599
working on it
Images: 457
Postby les45 » Mon Oct 01, 2012 5:55 am
Four coats of CPES on all wood skins, 4" fiberglass tape and Aeromarine layup epoxy on all corners, two coats of Zinsser oil based primer, and three coats of Rustoleum Safety Yellow. Used 4" foam roller on everything and thinned the last coat of Rustoleum by 25% with mineral spirits to get that smooth and glossy final finish.
les45
Images: 605
Postby Forrest747 » Mon Oct 01, 2012 11:42 am
AS I recall Zach used Kilz primer and then Rustoleum protective enamel.
I went the smae route, minus the Kilz.
I am happy with it. on top of it Rustoleum does come in alot of different colors nowdays.
http://www.rustoleum.com/CBGProduct.asp?pid=130 Gallon
http://www.rustoleum.com/CBGProduct.asp?pid=150 Quart I went with the Sunrise Red
96598
Forrest747
Cowbell Donating Member
Images: 447
Postby rmclarke » Tue Oct 02, 2012 10:38 pm
2 coats of Aeromarine epoxy, 2 coats of oil base primer, and 2 coats of Valspar oil base deck and porch paint
rmclarke
Images: 231
