Sealing Masonite
Sealing Masonite
Postby kookenotes » Thu Oct 04, 2012 10:26 pm
I am thinking of using 1/4" tempered Masonite for the roof of the Benroy woody I am building. It will be covered with with .040 aluminum with a one piece roof and a one piece hatch. Should I seal the edges of the Masonite, prior to installing the skin, with Epoxy, CPES, or are there any other alternatives? I understand that Masonite is tempered with a linseed oil bath so I assume I only need to worry about the edges. Also, is there a good thread out there on the use of epoxy exterior finishes under marine spar varnish? Thanks for any assistance. Bill
kookenotes
Images: 71
