by jonw » Fri Oct 19, 2012 5:05 am
I used 3/4in Okoume marine ply for the floor and 5/8 Meranti marine ply for my walls. They are both just different types of mahogany. Unless you are going for a specific grain pattern or color look I suspect the hardness and strength of each is comparable and either would be fine for any teardrop purpose.
IMHO the advantage of marine plywood is the use of waterproof glues, no voids, and all plys made from the same (hard) wood as is on the face. Hence no delamination from moisture, and any surface gouges will be less noticeable until repaired.
Personally I don't see the need to use CPES or other epoxy if using marine plywood. I just coated the bottom and exterior sides of mine with Helmsman Spar Urethane and it is doing just fine after a year.
It costs more, but should last longer with fewer problems, and can save finishing time if you are going for the woody look.
