Woodworking Joints Torture Test - Wood Magazine Nov 2006
Are pocket screws stronger than dowels? Which of the woodworking joints give the most strength? Do screw add any strength to a joint?
For the "Wood Joint Torture Test" in WOOD Magazine issue #173, they created and then destroyed more than 100 joints.
Wood Magazine Shear test:
Mortise & Tenon Joint took 1,005 lbs/force - over double to triple the force to break compared to other joints.
Wood Magazine Pull Apart test:
Biscuit miter joint 220 lbs/force; Dado 559 lbs/force - screws did not help.
For a Mortise & Tenon Joint, the wood failed but not the joint. It took 4,733 lbs/force nearly 2½ tons to pull apart.
Clearly, this test shows that the Mortise & Tenon joint is superior to other joints
