JunkMan wrote:One place where I see I can save weight is on my matress. I plan to use a standard household one, but if I went with a foam one it would weigh much less.
JunkMan wrote:Insulation doesn't add much weight, it's how you install it that adds weight. If you use 3/4" plywood sides, then insulation, then 1/8" or 1/4" plywood inside you add a lot of weight. If you frame it out with 1" dimensional lumber, and put 1/8" or 1/4" ply on the inside and out, you can keep the weight down. Check out mine, and other peoples build sites to see how some of us have done this..
toypusher wrote:Here's and example of lightweight wall construction. WARNING: I have not tried this and don't know anyone who has. Just and example that should work.
