Need tips on stretching my trailer!
My trailer floor is a frame made of square tubing with half inch plywood on top and bottom, insulated in the middle with foam insulation - here it is without the top added.
This sits on top of a trailer chassis from an old toy hauler. When I had the square tubing frame made, he made it smaller than I ordered. I'd intended it to be 1.5" wider so that the walls of the trailer would be closer to the wheels. Currently the wheels sit 3.5" out from where the trailer sides will be. I'd thought about just bolting a 2 x 4 on each side to widen the trailer and building the wall on top of it. It will add weight, but what can I do? What do you think? Any other suggestions? This picture shows the stage I'm at now:
-This sits on top of a trailer chassis from an old toy hauler. When I had the square tubing frame made, he made it smaller than I ordered. I'd intended it to be 1.5" wider so that the walls of the trailer would be closer to the wheels. Currently the wheels sit 3.5" out from where the trailer sides will be. I'd thought about just bolting a 2 x 4 on each side to widen the trailer and building the wall on top of it. It will add weight, but what can I do? What do you think? Any other suggestions? This picture shows the stage I'm at now:
