Faux Vinyl
Faux Vinyl
Postby Javier_Pacer » Wed Jan 16, 2013 10:32 pm
I have finally decided on an interior finish to try to keep build really simple. Cover interior walls with Faux Vinyl that has foam padding backing. My question for our experts on the forum are the following :
1) Can I glue Faux Vinyl diectly on sanded surface of harwood plywood sheet?
2) What type of adhesive to use? Will 3M spray suffice?
3) If not, how do I prepare harwood surface for adhesive.
Thanks all for reading.
Javier_Pacer
Re: Faux Vinyl
Postby CarlLaFong » Thu Jan 17, 2013 1:29 am
What is faux vinyl? Isn't vinyl faux leather?
At any rate, if it has a foam backing, 3M spray should work fine. Just follow the directions on the can.
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Re: Faux Vinyl
Postby Javier_Pacer » Thu Jan 17, 2013 11:15 am
Yes, Faux Vinyl can be found at the lowesst box store by the yard and has a foam backing but vinyl finish.
Should I seal the plywood first?
Javier_Pacer
Re: Faux Vinyl
Postby Javier_Pacer » Thu Jan 17, 2013 11:57 am
Thanks,
Should I seal the plywood edges with epoxy to help it not delaminate? It will not be in humid enviroment at all, it is all desert. :)
Javier_Pacer
Re: Faux Vinyl
Postby Shadow Catcher » Thu Jan 17, 2013 4:37 pm
Aren't Vinyls related to Nauga's I particularly liked the Wild Nauga's, ya the hid often had more flaws but it showed character 8)
Re: Faux Vinyl
Postby Tom Kurth » Thu Jan 17, 2013 5:26 pm
I work for a conversion company that puts living quarters in the front ends of horse trailers. Almost all of our trailers are done this way on the interior. A spray adhesive is fine over unsealed wood. (We usually line the interiors of the LQs with OSB.) 3M brand is fine but relatively expensive. A lumber yard or cabinet shop may be able to provide cheaper brand. If you have a lot to do and have access to air compressor and paint gun, it will be cheaper yet to buy in a regular paint can. If you do it this way make sure you clean your gun well with lacquer thinner after use. Make sure you let it tack up before applying.
Best,
Tom Kurth
Re: Faux Vinyl
Postby Javier_Pacer » Thu Jan 17, 2013 6:40 pm
Thanks Tom, do I spray wood only or both vinyl surface for better adhesion.
Thank
Javier_Pacer
Re: Faux Vinyl
Postby GerryS » Thu Jan 17, 2013 7:49 pm
I saw faux vinyl and immediately thought "isn't that leather?"
GerryS
