Page 1 of 1
Roof and headliner questions
Posted:
Fri Oct 14, 2005 2:16 pm
by Tiki Dude
Alright, we got the windows and door question taken care of, now I would like recommendations on readily found bendable ply for the headliner and roof. Any ideas. Thanks
Posted:
Fri Oct 14, 2005 2:27 pm
by Chris C
1/8 Birch works great. Or Maple, Red Oak, etc., etc., etc. You don't have to buy "bendy" plywood to do your liner.
Posted:
Fri Oct 14, 2005 2:31 pm
by mikeschn
1/8" plywood works even better if you rotate it 90 degrees so the grain runs across the teardrop.
Posted:
Fri Oct 14, 2005 3:33 pm
by bledsoe3
I used 1/8 luan. I used it like Mike said and I was able to bend it enough to put thru the door easily.
Posted:
Fri Oct 14, 2005 6:37 pm
by JunkMan
I'm using 1/8 Baltic Birch (it's actually 5.2 mm or something close to that). It's availible in 5' x 5' sheets, so there is little waste if you are building a tear that's wider than 4', and seems to bend very easy.
Posted:
Fri Oct 14, 2005 10:54 pm
by Hardin Valley Magic
I actually used beaded board tongue and grove. 4 ft. wide put spars in and slide it in from the front and started at the cabinets and came forward with it..Just my experience..First time builder..
Re: Roof and headliner questions
Posted:
Sat Oct 15, 2005 10:48 am
by TomS
Tiki Dude wrote:Alright, we got the windows and door question taken care of, now I would like recommendations on readily found bendable ply for the headliner and roof. Any ideas. Thanks
Is this stuff flexible enough for you?
I used 1/8" Bending Birch from
Boulter Plywood in Sommerville, Mass. That stuff is so flexible it's amazing. It's probably overkill for the headliner in the cabin. It was a Godsend for skinning my galley hatch. I had no springback problems whatsoever.
I also used their Wacky Wood, a 3/8" 2-ply flexible luan for my exterior roof skins.
Posted:
Sat Oct 15, 2005 11:30 pm
Toms is the birch made the same way as wacky 3/8??Might be worth checking out for next tear....
