Hardboard installation
Postby Javier_Pacer » Thu Jan 31, 2013 7:31 pm
I have spars across horizontally spaced at 17 inches top to bottom. Would 3/16 4x8 hardboard on the sides and 1/8 hardboard on roof interior hold up? humidity? disintegration?
Not worried about weight.
thanks
Javier_Pacer
Re: Hardboard installation
Postby Woodbutcher » Thu Jan 31, 2013 7:57 pm
It would not be my choice. Moisture is not it's friend. My choice would be 1/4" plywood. Other may disagree but so far I have yet to see a teardrop made with masonite/hardboard. Is there some reason you want to use it?
Woodbutcher
Postby Javier_Pacer » Thu Jan 31, 2013 8:22 pm
Seems cheaper. Thats why I ask you, the experts :)
I really have not found anything else than 1/4 plywood.
So if I use 1/4 plywood, will crown staples to 5 horizontal spars hold?
Thanks
Javier_Pacer
Postby Javier_Pacer » Thu Jan 31, 2013 8:27 pm
Of course I would be using this if aplicable inside cargo trailer sides an roof, not teardrop... :lol:
Javier_Pacer
Postby Javier_Pacer » Thu Jan 31, 2013 8:43 pm
I dont plan to have any leaks, well thats the plan. :lol:
CT is all aluminum outside skin and well sealed. Here in the desert I dont worry too much.
Other than that, you think it will be ok then?
Thanks
Javier_Pacer
