Attaching interior paneling
Postby Javier_Pacer » Sun Feb 10, 2013 2:36 pm
How can a finishing interior panel be attached to furring strip wall without showing attachement screw/staple/etc and no moldings to cover attachment points.
Thanks.
Javier_Pacer
Re: Attaching interior paneling
Postby 48Rob » Sun Feb 10, 2013 3:13 pm
Gluing the panels would be one method.
Rob
48Rob
Postby rowerwet » Sun Feb 10, 2013 3:18 pm
glue
rowerwet
Images: 521
Postby Woodbutcher » Sun Feb 10, 2013 4:57 pm
Glue with a cross pieces of wood, pressure fit between the two walls works good. Use some wood with a little spring in it. Then when the glue dries remove them. A good panel adhesive like Liquid Nails would do.
Woodbutcher
Postby Javier_Pacer » Sun Feb 10, 2013 5:31 pm
Thanks, will polyurathane caulk work as well or am I over killing it? It is more expensive but has more elasticity.
Javier_Pacer
Postby 48Rob » Sun Feb 10, 2013 5:37 pm
I really like polyurethane.
It has held my trailer together for many years now with no signs of failure.
You must be aware however, that polyurethane is a "moisture cure" glue, and won't bond well if applied to very dry surfaces.
If the surfaces are dry, and there is low humidity, it is beneficial to use a damp rag to wipe the areas to be glued.
Rob
48Rob
