Polyurathane and Gravity Feed Spray Gun
Postby Javier_Pacer » Thu Mar 07, 2013 12:00 pm
Do they mix together? Is it a better option to lay multiple coats of clear?
Thanks :D
Javier_Pacer
Re: Polyurathane and Gravity Feed Spray Gun
Postby Bigblock352 » Thu Mar 07, 2013 12:29 pm
Yes, You can spray it with HVLP or siphon. It helps to thin it a little, no more than 10%. Also watch the overspray it gets nasty. And clean that gun right after use. It sets up fast and will ruin that gun.
Bigblock352
Images: 39
Postby jonw » Thu Mar 07, 2013 5:02 pm
I used a HVLP sprayer from Harbor Frieght with Minwax Spar Urethane and it came out great.
I was expecting to need to thin it but it was a warm day (in the 80s) and I didn't need to. Put on several coats over two days with a light sanding in between.
Just make sure you mask everything you don't want sprayed.
jonw
Titanium Donating Member
Images: 163
