Plasti Dip?
Plasti Dip?
Postby Irving » Fri Mar 08, 2013 12:12 am
I am exploring all different finish options for my planned travel trailer. Just ordered a HF 4x8 trailer. Taking my time doing research.
I have considered aluminum as a outer covering and am also looking into RotDoctor products CPES and Elasta-Tuff 6000.
I'm considering any flexible, thick, and durable finish that I can apply directly to the wood.
I have come across this curious product called Plasti Dip. It is a coating that can be sprayed or brushed and hardens to a flexible rubbery coating. I don't quite understand what the phenomeno around it is. People seem to be spraying their cars with it quite a lot which I find pretty odd at the moment.. I must be missing something. Apparently it's used a lot of tool handles, car rims, trailers, truck beds and so forth.
Anyone ever used it to coat the outer shell of a teardrop or similar travel trailer?
Irving
Re: Plasti Dip?
Postby H.A. » Fri Mar 08, 2013 1:45 am
There is the sprayed urethane stuff commonly called truckbed liner, It will stick well to most anything..
Can be applied in multiple coats to what ever thickness one might want.
There are several brands of it.
I understand some shops are kind of weird about accepting a job, if its not a pick-up truck bed they wont touch it.
I personally know of others will spray anything you are willing to pay for.
good luck to your project
H.A.
Re: Plasti Dip?
Postby Vindi_andy » Fri Mar 08, 2013 3:55 am
There is a product over here called Wunderseal its a rubberised underseal product but can be overpainted. It is useful as an underseal on fibreglass and when stones are thrown round the wheel arch the rubber absorbs any impacts and the stone doesnt damage the fibreglass.
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Re: Plasti Dip?
Postby mezmo » Fri Mar 08, 2013 9:16 pm
Check out these links:
A build:
http://www.expeditionportal.com/forum/t ... -Kubic-1-0
The product they used:
http://www.uro-cover.com/web/
http://www.uro-cover.com/web/fabricacion-2/
It's from Spain, but just Google the product type [Urea/Polyurea]
~ to bed liner.
Also check out this thread:
http://tnttt.com/viewtopic.php?t=46662
mezmo
Images: 194
Re: Plasti Dip?
Postby working on it » Fri Mar 08, 2013 10:36 pm
I have a little experience with Plasti-Dip, and was favorably impressed. About 18 months ago, I sprayed two coats of the black on the grille of my HHR. I didn't like the factory silver/argent look or the pitting that was beginning to occur (during my 120 mile daily commute, my vehicle is subject to a constant peppering of sand and gravel from all the road construction and the trucks that transport the material). Also, I wanted to replicate the black/textured look of some other parts of the front end. So I sprayed it, not really sure of future outcome. To my surprise, the effect was as desired, and much more durable and protective than I expected.103080 There has been some wear, and abrading, and one spot took a direct hit from tire tread, but not enough to need to recoat after 50k miles. I will recoat in a month or so, and use it also to cover over the polyurethane drips on my trailer's fenders (should've covered 'em!). However, I got Plasti-Dip at Home Depot; on my last trip there Monday, it had been replaced by a Rustoleum product. If I can't find the original...that may be my substitute.
173193172890148599
working on it
Images: 457
Re: Plasti Dip?
Postby mallymal » Wed Mar 20, 2013 5:31 pm
I'm on a motorcycle forum, and one of the guys took a virtually new Suzuki, and painted all the painted surfaces with Plastidip, in a matt metallic grey. very mean & moody! But he reckons if he ever changes his mind, he can just snik it with a sharp blade, pick at the edge, and peel it off! Here's a guy doing something similar with his car wheels:
http://www.youtube.com/watch?v=SxxfHI4V7jo
mallymal
Images: 18
