Page 1 of 2
My Modified/Homemade Roof-Wall Mldg.
PostPosted: Fri Mar 08, 2013 4:34 pm
by AlgoDan
Re: My build of Benroy Style Trailer
Postby AlgoDan ยป Fri Mar 08, 2013 4:26 pm
Ok next stage of build is Roof/wall moulding trim. I have searched high and low for it, I would need to order from the U.S , I would get raped by UPS on shipping/duty... So I thought of going with outdoor PVC...Went to Homer Depot last night picked up some PVC trim moulding for windows. So I picked up a piece of 12ft.long at $15 per.length. This stuff is light ,flexible, wont crack so hey give it a try! Comes in white only but is paintable. It cuts nice, drills and countersinks great. So I did a sample piece, had to use table saw to cut the profile I wanted. I did a piece with and without radius edge. The router leaves somewhat of a rougher finish, perhaps maybe two passes would help.... Anyhoo a few pictures posted of a sample and a fitted piece on the front radius of trailer..Let me know what you think. Cheers
103067
103068
103069
Also dimensions of the finished Moulding is 1.6 Wide X .670 High X .200 Wall
Re: My Homemade Roof/Wall Mldg.
PostPosted: Fri Mar 08, 2013 5:03 pm
by Bigblock352
Good Idea. How tight of a radius you think it could make?
PostPosted: Fri Mar 08, 2013 5:11 pm
by AlgoDan
Thanks, as for radius I have a front radius of 24inches and no problem at all, you could go smaller.....Cheers :beer:
Bigblock352 wrote:Good Idea. How tight of a radius you think it could make?
PostPosted: Fri Mar 08, 2013 7:27 pm
by S. Heisley
PVC sands pretty well; so, you can take care of a lot of the rough stuff with a little sand paper.
PostPosted: Fri Mar 08, 2013 7:38 pm
by AlgoDan
Ya I did sand my sample piece, as you said it does sand quite well...Cheers
PostPosted: Sat Mar 09, 2013 8:03 am
by AlgoDan
Some more pics of moulding....
103089
Moulding on 3/4 ply.
103090
Moulding Radius
PostPosted: Sat Mar 09, 2013 12:09 pm
by Greg M
With some heat it becomes so flexible you could wrap it around a quarter.
PostPosted: Sat Mar 09, 2013 1:21 pm
by AlgoDan
Greg M wrote:With some heat it becomes so flexible you could wrap it around a quarter.
Ya it can flex for sure.
PostPosted: Sat Mar 09, 2013 1:24 pm
by AlgoDan
biziedizie wrote:I messed around with a few pieces of this stuff this morning and it sure does flex :)
With some sealant behind it and some screws this product aint going to move :)
Cool, always willing to try something different, Cheers :beer:
PostPosted: Sun Mar 10, 2013 5:24 am
by AlgoDan
Ok added some more moulding pics. I have profile shots of the store bought moulding and of the modified one to what I need. The one profile being square and the other having a radius...The screw caps will go into a counterbored hole. I will put a dab of sealer/caulking in each hole, then tap the cap on....
103108
103107
103106
103104
103105
PostPosted: Sun Mar 10, 2013 12:09 pm
by grant whipp
Hey, Dan!
Just a small suggestion, if you don't mind ... instead of having those white caps sticking up above the molding, why not consider using domed-head counter-sunk stainless steel screws?
Very interesting and unique adaptation of materials! I'm keeping an eye on this thread ... ;) ...!
CHEERS!
PostPosted: Sun Mar 10, 2013 12:35 pm
by AlgoDan
Hi Grant, You do some nice work I must say....Thanks for looking, yes I like your idea...those caps are hokey but had to check them out. I am thinking whatever looks good, seeing that I am using stainless hardware anyway....why not.
Cheers
Dan
grant whipp wrote:Hey, Dan!
CHEERS!
PostPosted: Sun Mar 24, 2013 6:03 am
by AlgoDan
Picture of moulding on the trailer, sorry for the in the garage pic, should be outside.
103569
PostPosted: Tue Mar 26, 2013 10:41 pm
by cpowell243
I'm also considering this product for my build with white fiberglass skin. For those viewing this thread, think it would work to attach the molding to the galley lid, having the piece extend beyond the lid by 1/2", thus leaving a 1/2" gap so the molding could slide over a 1/2" plywood wall? Seems like I would have 1/2" of material to glue/screw to the galley lid, and with some weatherstripping on the inside of the molding, wouldn't I have an adequate seal?
Th - CP
PostPosted: Wed Mar 27, 2013 4:50 am
by AlgoDan
No reason it would not work,it is strong yet light and can be screwed and glued. I would do it and easy to work with also.
powell4 wrote:I'm also considering this product for my build with white fiberglass skin. For those viewing this thread, think it would work to attach the molding to the galley lid, having the piece extend beyond the lid by 1/2", thus leaving a 1/2" gap so the molding could slide over a 1/2" plywood wall? Seems like I would have 1/2" of material to glue/screw to the galley lid, and with some weatherstripping on the inside of the molding, wouldn't I have an adequate seal?
Th - CP
