a problem changing wheels from 12" to 14" ?
I though that changing tire and wheels from 12" to 14" was as easy as buying new tires and wheels and mounting them. Apparently not.... the first issue I ran into was that my hub and drums are not fitted with mounting studs as most hub/drums assemblies but instead have tapped holes for lug bolts like these:
I'm not sure that these bolts will be compatible with these wheels:
My second question and one that is more puzzling to me is the issue of the pilot diameter on the wheel. I've read that because my wheels are mounted with bolts and not nuts on the stud from the hub that my wheel is "hub-centric" and the pilot diameter of the wheel needs to match the hub. Apparently in autos, if these measurements don't match (pilot diameter is larger than the hub needs) this can cause vibration...
Anyone out there know about this kind of stuff?
I'm leaning toward making the swap anyway but I certainly don't want a wheel flying off at highway speed. I've seen it happen before and I know it would cause a lot of damage or injury, never mind the damage to my Road Foamie.
