hatch hinge point
hatch hinge point
Postby markhusbands » Fri Mar 22, 2013 8:38 am
Any tips on where to position the galley hatch hinge point? Seems like you want a bit of slope for drainage, but not so low that the hatch opening radius gets too large...
133923
markhusbands
Images: 58
Re: hatch hinge point
Postby Irmo Atomics » Fri Mar 22, 2013 8:50 am
I made my hatch first - 45" along the outside radius so that 1 sheet of 4 ft wide aluminum would cover it. The hinge point was where the top of the hatch cover happened to end up.
Bob
Irmo Atomics
Images: 64
Postby markhusbands » Fri Mar 22, 2013 12:54 pm
Huh. Reasonable logic, but using my rudimentary math skills, and knowing that I have a four foot high wall with a 3 foot hatch radius, the base of the wall to the end of the radius is 5.71 feet. So a few inches back from that is still well over 45"...
133923
markhusbands
Images: 58
Postby Irmo Atomics » Fri Mar 22, 2013 4:18 pm
OK, so I built the hatch first, fit it on the camper and fit the hinge to the hatch. The 45” reference was just me showing off about how frugal I was with my materials. No actual math was used in the construction of my teardrop… hell, I barely had a plan!
I’d say just stand back and to see what looks right. It’s like a roof vent in that no matter where you put it, it will need to be sealed properly. And let the hinge overhang the sides a little to drop the water away from the hatch.
96745
Bob
Irmo Atomics
Images: 64
Postby markhusbands » Sun Mar 24, 2013 9:20 am
Well, with the "ducktail" rear end I can certainly see how you managed such as short hatch. Which is nice. Thanks for the replies.
133923
markhusbands
Images: 58
