10' TD on a 8' frame?
Postby jgriffin8 » Wed Mar 27, 2013 1:46 pm
Newbie question -- I'm using SketchUp to design a 10' TD on an 8' Northern Tool trailer frame. The front and back is curved in at the bottom, but there is about a foot overhang higher up. Is this a dumb idea or am I asking for problems by doing this?
jgriffin8
Re: 10' TD on a 8' frame?
Postby bobhenry » Wed Mar 27, 2013 1:57 pm
NOPE ! however opinions may vary
"Chubby" is 10' nose to tail on an 8' frame with a foot over at front and a foot at the rear.
and my 10' "Barn to be wild" has a 2' cantilever at the front off of an 8 foot frame.
Postby jeff0520 » Wed Mar 27, 2013 2:34 pm
Take a look at the Command Post. 13 feet overall length and 77 inches wide on an HF 4X8 frame. (Link to build in signature) You will be fine if you build a solid floor structure and tie the walls and roof in firmly. All the parts share the load and stiffen the structure.
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby jgriffin8 » Wed Mar 27, 2013 2:36 pm
Thanks Bob! The pictures are really helpful. :D
jgriffin8
Postby jgriffin8 » Wed Mar 27, 2013 2:39 pm
Thanks Jeff. I will read the build journal. I like the portable garage idea too. I will check that out.
jgriffin8
