Page 1 of 1
anyone using this pocket hole jig?
PostPosted: Thu Oct 20, 2005 12:30 pm
by surveytech
anyone using this pockethole jig from harbor freight?
wondering how well it works.
Its 6.99......the kreg mini jig is about 20.
PostPosted: Thu Oct 20, 2005 12:55 pm
by Nitetimes
I've got the Kreg myself, my question is, does that come with anything else, ie, bit, clamp, stop collar. And how do you clamp that? It doesn't look too user friendly. If you have to buy the bit and such you won't be saving much I don't think. I could be wrong but I don't see anything else in the pic.
Kinda nice that it's adjustable but I'd have to see one before buying it I think.
But for $7 what the hey, pick one up and let us know how it works. Just my .02 worth.
Oh yeah, the mini jig is a single I believe, the one comperable to that is closer to $50.
PostPosted: Thu Oct 20, 2005 1:03 pm
by mikeschn
I bought a jig like that when I was working on the weekender. I broke the bit that came with it the first day. I never replaced the bit.
What I did notice is that it tended to pull on the joint a little bit, pulling the surfaces out of line.
If I were to try again, I think I would use a combination of biscuits and poket hole joints. But for what I do, biscuits is all I need!
PostPosted: Thu Oct 20, 2005 1:51 pm
by Boodro
Mike , a little gravy with them biscuits??? :twisted: :twisted: Cooked in a DO !! :lol: :lol:
PostPosted: Thu Oct 20, 2005 2:32 pm
by TomS
I've had very good experience with the Kreg Jigs. The Mrs. gave me the deluxe set for Christmas. It's also gotten me out of a few jams when working in tight spaces.
PostPosted: Thu Oct 20, 2005 5:16 pm
by surveytech
I think what you see is what you get.
drill bit is extra.
I cant figure out how it works.
the kreg looks easy but this has a lot more moving parts.
just curious.
thanks.
PostPosted: Thu Oct 20, 2005 5:22 pm
by PaulC
Excuse my ignorance over here in the Land of OZ, but what the heck does a pocket hole jig do. I do not need any more holes in my pockets :lol:
PostPosted: Thu Oct 20, 2005 6:20 pm
by madjack
if you want to join 2 boards edge to edge (say 2, 1xwhatevers) or end to end (got that) A pocket jig is a jig with a special drill bit that allows you to make a "pocket" on/in the backside of one of those boards to allow you screw them together using a special pocket hole screw in an almost straight line...clear as mud now...good. It is used most commonly in joining rails and stiles together while making cabinets
madjack 8)
PostPosted: Thu Oct 20, 2005 8:32 pm
by TomS
I have a slideshow on my web site that shows how pocket screws work.
[/url]
PostPosted: Sat Oct 22, 2005 7:52 am
by Guest
I have that exact jig. I found that if you don't clamp it right (not on the set screw) it works just great. Just a side note, I only use the 90 degree bit.
For those that will ask (or are only lurking), these type of jigs can use two types of bits; 90 degree, and counter sunk.
The 90 degree bit will leave a flat bottom to your pocket.
The counter sunk bit works just like counter sinking a screw on the surface of anything. It will leave a counter sunk, or pointed bottom in your pocket.
I also use a end clamp (a clamp that holds two pieces of wood at 90 degrees to each other, like a T) to help hold the whole mess steady.
And speaking of pockets, I like my Steelex jig because it didn't leave a big hole in my pocket.
PostPosted: Mon Oct 24, 2005 12:22 am
by PaulC
Thanks Madjack and TomS. I used dowels and a Heavy duty glue. No wonder it took forever waiting for everything to dry. This system looks much quicker, easier and stronger.
Cheers PaulC :thumbsup: :thumbsup:
