Page 1 of 1
Bonding aluminum trim to painted tear
PostPosted: Sun Apr 28, 2013 6:44 pm
by Irving
I have a canvas coated and painted teardrop that I want to apply aluminum trim to (just around the bottom). I'd like to not use any screws, rivets or nails. What do you think is the best caulk/adhesive to attach aluminum to a painted surface?
Re: Bonding aluminum trim to painted tear
PostPosted: Sun Apr 28, 2013 6:48 pm
by eamarquardt
I dunno but I'd visit an automotive paint store and follow their advice.
Cheers,
Gus
PostPosted: Sun Apr 28, 2013 7:37 pm
by Irving
eamarquardt wrote:I dunno but I'd visit an automotive paint store and follow their advice.
Cheers,
Gus
That sounds risky.. haha
PostPosted: Sun Apr 28, 2013 8:19 pm
by eamarquardt
Cheers,
Gus
Nothing is risk free. You are free to disregard their advice, ha.
Cheers,
Gus
PostPosted: Sun Apr 28, 2013 8:49 pm
by Shadow Catcher
I would try 3M VHB tape
PostPosted: Sun Apr 28, 2013 8:56 pm
by S. Heisley
Since you want to bond to paint, this probably isn't exactly what you want to hear. However, please recognize that, unless you put in a few screws, your bond will only be as good as the paint that is bonded to the tear. If the paint lets loose, so will your trim. If I were using screws (...I would...), I would drill the screw hole through the trim and into the wood; put a dab of RV silicone gel in the drilled hole and screw on the trim while the gel is still wet. Wipe off the excess silicone that squeezes out around the screw immediately with some mineral spirits on a cloth or paper towel.
PostPosted: Mon Apr 29, 2013 6:33 am
by webbaldo
If you sanded the paint down it might help, but in the end they are correct, only as strong as the paint itself. Maybe try a small test area and see if you can pull it off? I tried this first when testing what glue was best for my aluminium to plywood.
