I am preparing to add some spar urethane to the our woodie. The original finish is beginning to show signs of wear. There is a thin line of clear caulk that I think is silicone where the roof meets the the trim at the side edge. There is also some of the same caulk in a few other places. I am assuming that this should be removed before applying more finish. What would be the best way to remove it without scratching up the wood?
Is it possible that I could get away with leaving it and applying urethane to the edge of the caulk? The caulk is still in good condition.
