Door latch dimentions ?
Postby RogHodge » Sun May 19, 2013 2:54 pm
I'm building door/s hollow core. I need a block to mount the latch. The question, what size? I will likely go with the lil bear latch but can't find dimentions for them.
Also thinking about a single door, the trailer will be use mostly by me alone, or with the wife, or with one daughter, but I'm the only one who makes midnight potty runs.
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Re: Door latch dimentions ?
Postby LDK » Thu May 23, 2013 6:07 pm
I also used the lil bear latch and mine measured 2" by 3-3/8". I also used a 1/4" thick block to stand it off from the door enough so it would latch properly. My door and camper is 3/4" oak ply.
On the outside I had to recess part of the t-molding so the handle would fit.
Hope that helps.
LDK
Postby grant whipp » Thu May 23, 2013 9:47 pm
Thanks, Larry!
I keep forgetting to take measurements while I'm in the shop ... :oops: ...!
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby RogHodge » Thu May 23, 2013 10:38 pm
Yes very helpful, thank you
RogHodge
Images: 51
