Page 1 of 1
Wall construction choices
Posted:
Wed May 22, 2013 1:32 pm
by IslandStorm62
From what I've seen there are two basic wall constructions (I think)
1 - Use a 3/4" Birch Plywood and layer on your preferred outside skin and inside skin. Spares run from one wall to the other, creating space for insulation in the roof. There does not appear to be insulation in the walls or space to connect light switches (did I miss something?). It also appears that the 3/4" Plywood provides enough support for the door and window frames.
or
2 - Use 1/2" Birch Plywood with internal framing (not sure what is used for the framing) to support doors and windows, as well as provide space for mounting light switches and adding wall insulation. Again, apply choice of exterior and interior skin. In this case the spares would run from wall to wall. But, will there also need to be framing a around the wall edges?
Any pros or cons you can provide to help me decide which technique to use, is as always, appreciated.
Re: Wall construction choices
Posted:
Wed May 22, 2013 2:29 pm
by halfdome, Danny
I build with 3/4" plywood and make 1/4" x 3/4" stop dadoes where I need light switch wire chases.
I also dado in the front & rear bulkheads and the floor.
The glued on 1/8" Oak interior plywood covers up the dadoes and the glued on aluminum covers the exterior.
I've tried your #2 and the extra materials and effort weren't worth it to me.
Good luck with your build.
Danny
Posted:
Wed May 22, 2013 3:27 pm
by IslandStorm62
I have little (almost none) wood working skills, so I have google everything.
If I understand correctly, your dado runs from the ceiling down to where you want the light switch, and you have no wall insulation. Just an interior skin that covers all you wiring.
As far a the front bulkhead, I don't understand that. The front of the teardrop (what I assume you are calling the front bulkhead), as i understand it, is just part of the roof extended down or it starts from the front and follow the form of the teardrop to make the roof, outside of the spares.
Posted:
Wed May 22, 2013 5:08 pm
by halfdome, Danny
IslandStorm62 wrote:I have little (almost none) wood working skills, so I have google everything.
IslandStorm62, You could take a woodworking class at your local community college to hone up on your skills.
It would be very helpful with your build.
Yes, I run just the wires that operate the light switch in that dado and nothing else.
My teardrop is a 5' x 10' and it affords a front closet, therefore a front bulkhead.
Danny
Posted:
Fri May 31, 2013 2:41 pm
by markhusbands
I'm doing the same thing as Danny but running the dadoes for wires on the outside and just staining the interior finished ply. And for clarification, all my interior lights and switches I'm just going to put on the roof or wire through a cabinet. The exterior dadoes are for wires to running and porch lights (just a few inches each), and will get covered by aluminum.
Posted:
Fri May 31, 2013 3:01 pm
by Oldragbaggers
If you are using solid 3/4" plywood for your walls you do not need to skin them inside and out unless you are planning on an aluminum or other such exterior. You can either get ply with one nice face and put that toward the inside if you are covering the exterior with aluminum or painting it. Or if you want woodie on both sides get plywood with two nice faces. Running wires can be done inside your roof and cabinets. The dado idea is perfect for wire runs that have to go into the wall. No need buying 3 sheets of anything when one sheet will do.
The second method, with sandwich construction (framing covered on both sides with ply) would certainly not require 1/2" ply for a skin. That seems like overkill to me. I have sandwich construction and my skins are only 1/8" inside and out. I did fiberglass mine, so that gives my exterior skin some strength and puncture resistance, but I think even if I had not fiberglassed, the thickest skin I would have used is 1/4".
If I had it to do over, considering the additional work and expense of the sandwich construction, I would go with 3/4" solid walls. And especially if you have little or no woodworking skills. Building a frame, figuring out where you need to leave solid wood for all your cabinet, fender, and other attachment points and so forth lends a fair amount of complication to the project. And I think I only saved myself about 25 pounds over all with my sandwich construction (I used plywood for my interior frame) so for the weight savings, and the most likely limited amount of sound and temperature insulation gained, I don't think it was worth it.
Just my 2 cents.
Posted:
Fri May 31, 2013 3:27 pm
by halfdome, Danny
Oldragbaggers wrote:If you are using solid 3/4" plywood for your walls you do not need to skin them inside and out unless you are planning on an aluminum or other such exterior. You can either get ply with one nice face and put that toward the inside if you are covering the exterior with aluminum or painting it.
I use 1/8" Oak plywood on the interior as vertical grain looks nicer than horizontal.
In a house, wainscot, cabinets including door panels run vertical too.
The flames in the grain should go vertical.
On drawer fronts & tops, the flames should go to the right.
It was the way I was trained as a cabinetmaker.
Some may not care, but that's the way our eyes see things more pleasing.
I use 3/4" plywood that has a not so attractive face and back as it all gets covered.
Danny
Posted:
Fri May 31, 2013 8:37 pm
by doug hodder
+1 on the interior grain direction Danny. Nothing looks more our of place to me than horizontal grain on an interior. Others opinions may vary. Yes, it does take more time but it's worth it. Doug
Posted:
Fri May 31, 2013 9:25 pm
by Oldragbaggers
I guess I must have very unsophisticated eyes. Wood grain looks great to me running horizontal, vertical, diagonal or whatever.
Good thing I painted mine I guess.
Posted:
Sat Jun 01, 2013 6:14 pm
by 48Rob
Becky,
I agree that wood grain, no matter the direction, is pretty, but sometimes orientation makes it better...
Rob
Posted:
Sat Jun 01, 2013 6:20 pm
by Oldragbaggers
Very beautiful, Rob. No doubt you know your wood!!
Posted:
Sat Jun 01, 2013 7:54 pm
by working on it
Oldragbaggers wrote:I guess I must have very unsophisticated eyes. Wood grain looks great to me running horizontal, vertical, diagonal or whatever.
+2... I love the look of plywood for some reason; I sorta regret painting over my exterior, poly-urethaned and glossy, every time I look thru my gallery photos. But, I had a plan to paint it black/gray/silver and did it. Needed UV protection anyway.
Posted:
Sun Jun 02, 2013 6:47 am
by markhusbands
Boys, my flames run horizontal because I'm fast. Real fast.
Okay, it's mainly because I'm cheap. Two walls, two 80 dollar sheets of plywood with a finished side. Done.
