G'day All,
Bit of a curious question... Has anyone ever done a teardrop design - specifically geared to being cut on a CNC?
My little modified JGRO 4x2' CNC router - has me thinking about a revamp - building a full 5x10 table... Life's a whole lot easier when you slide a sheet of plywood onto the table, Load up a file, then click cut. Took me 5-6 hours to cut my teardrop sides... took all of 5 minutes to resize that same side to fit the build area, export the Gcode, and re-cut it on the router...
And there's a certain - Je ne sais quois - to insert tab A into slot B as a construction methodology... Also means lightening holes, and conduit runs, etc - can be designed into the base design, saving even more manual labour as construction progresses...
Andy
