Using the PC template bushings without modifiying them???
I now have all of the router parts I ordered. Some of the Porter Cable template bushing guides (the part that rides the edge of the template) are actually too long to use on a 1/4" thick plywood template and let the router ride perfectly flat on the template. My thinwall 1/4" and 5/16" bushings have a guide about 1/8" deep and are OK to use as is. The thickwall 1/4" and 3/8" bushings have a guide about 5/16" long, a little longer than the template thickness, but that extra 1/16" may not pose a problem. The 1/2" and two 5/8" bushings have a guide of about 9/16" long, a little over twice the template thickness.
I added my original router base below the PC base I had just put on, and then measured the 1/2" bushing guide from below the router base and the guide still extended down a shade over 1/4" below the 2nd base, but looked usable.
One possible solution I cameup with to use the 1/2" bushing is to cut a piece of 1/4" plywood or preferably, masonite, which is slightly thicker than the 2nd router base and drill a hole for the cutting bit to stick through. Then, remove the extra base from the router and double stick the piece of plywood or masonite on it. That would make the extended portion of the guide 1/4" long or slightly less. Another is to use a forstner bit and shave the recessed portion of the base that holds the bushing about 1/16" deeper. I believe that that the base would still be strong enough to hold the bushing and that would help resolve all of the problems as long as I used the extra base with the longer 1/2" bushing.
Has anyone else faced this problem and how did you resolve it?
