by Juneaudave » Tue Nov 01, 2005 12:54 am
This might be relevant...at least interesting...I'm planning on building stripper type "Woody" sides and paint the roof and hatch (to match the tow vehicle) over 4 oz glass. I contacted West Systems regarding painting, with the hope that I could put the primer and color coats on the roof, then shooting the whole shebang with clear coat. That would avoid the tedious spar varnish for UV protection and should put a pretty nice finish on. Here was the response (which I thought confirms my experience, at least with polys over glass)...
Dave,
As long as the 105/207 you use on your final coats over the wood are fully cured, washed, and sanded you shouldn't have any problems. There are certain coatings that do not dry if the epoxy hasn't fully cured or is mixed off ratio. If your shop is below 60-65°F, the epoxy will take longer to come to a final cure.
I would say to coat the entire project with 105/207 and allow it to cure. When you are certain the cure is adequate, wash with water and follow the paint manufacturer's surface prep for fiberglass. As long as your clear has a good UV resistance to protect the epoxy, there shouldn't be any problems there. Regardless of the information I have sent you here, its always a good idea to create a test panel with the exact products you are using in the environment you are using them in. The stress levels involved are much lower if you're troubleshooting why your test panel didn't turn out vs. your entire project.
This next section is taken directly from Westsystem.com - it gives a guideline for compatibility with certain types of paint.
Finish coatings
The function of a finish coating like paint or varnish over an epoxy barrier coat, is to decorate the surface and protect the epoxy from sunlight. In doing so, the finish coating extends the life of the epoxy moisture barrier, which, in turn provides a stable base that extends the life of the finish coating. Together the two form a protective system far more durable than either coating by itself.
Protection from sunlight is a primary consideration in the selection of a finish coating. Long term UV (ultraviolet) protection of the barrier coat depends on how well the finish coating itself resists UV and keeps its pigments, or its shield of UV filters on the surface of the epoxy barrier coat. A high gloss finish reflects a higher proportion of the light hitting the surface than a dull surface. All other thing being equal, a white (especially a glossy white) coating will last the longest.
Most types of coatings are compatible with epoxy. Thoroughly cured epoxy is an almost completely inert hard plastic. This means most paint solvents will not soften, swell or react with it. However, it is still a good idea to build a test panel to assure coating compatibility.
Coating types
Latex paints are compatible with epoxy and they do an adequate job of protecting the epoxy barrier from UV radiation. In many architectural applications latex paint may be the most suitable coating to use. Their durability is limited.
Alkyd finishes-enamel, alkyd enamel, marine enamel, acrylic enamel, alkyd modified epoxy, traditional varnish and spar varnish-offer ease of application, low cost, low toxicity, and easy availability. Their disadvantages are low UV resistance and low abrasion resistance.
One-part polyurethanes offer easy application, cleanup and better properties than alkyds. They are also more expensive and some may be incompatible with amine cure epoxy systems such as WEST SYSTEM epoxy, although 207 Hardener may offer better compatibility. Test first.
Epoxy paints are available in one-part and two-part versions. Two-part epoxies offer many characteristics similar to the higher performance polyurethanes. They are durable and chemical resistant, but offer limited UV protection compared to the linear polyurethanes.
Two-part linear polyurethane (LP) paints offer the most durable protection available. LP's are available as pigmented or clear coatings and offer excellent UV protection, gloss retention, abrasion resistance, plus compatibility with epoxy. However, compared to other types of coatings, they are expensive, require more skill to apply and present a greater health hazard, especially when sprayed.
Bottom paints are available in a variety of formulations. Most bottom paint systems are compatible with epoxy and can be applied directly over a prepared epoxy barrier coat. If you are unsure of compatibility or have curing or adhesion problems with a specific bottom paint, use only a primer recommended for that bottom paint over the barrier coat. Follow the recommendations given for preparation of fiberglass surfaces. Other paints, including marine LP's and primers, are not recommended for use below the waterline.
Primers are usually not needed to help a paint film bond to epoxy, although interfacing primers may be required with some specialized bottom paints and high-build primers are useful for hiding scratches or flaws in the substrate. If the instructions on your paint or varnish recommend a specially primed surface, follow the recommendations given for fiberglass preparation. Self-etching primers do not work well on an epoxy coating because of epoxy's chemical resistance.
Polyester gelcoat is a pigmented version of the resin used to build fiberglass boats and other products. Gelcoat is sprayed into a mold before the glass fabric and resin are applied to provide a smooth pre-finished surface when the part is removed from the mold. It is not often used as a post-production finish coating, but it can be applied over epoxy and is useful in some repair situations. Refer to 002-550 Fiberglass Boat Repair and Maintenance, published by Gougeon Brothers, for detailed information on patching gelcoat over an epoxy repair.
If you have any other questions, feel free to write me back. I am also curious to see a digital picture of the final outcome if thats possible.
For what it is worth...Juneaudave
