What is the most common method of attaching a plywood floor to the frame and then the walls to the floor. Considering a bolt thru the bottom wall runner, thru the floor and thru the frame.
Any suggestions appreciated.
muzz wrote:What is the most common method of attaching a plywood floor to the frame and then the walls to the floor. Considering a bolt thru the bottom wall runner, thru the floor and thru the frame.
