Well I finally made up my mind,,,, dang its tough when ya done have a full time female to guide ya thru tough decesions in life,,,, being un supervised does and doesnot have its advantages,,, but anyway,,, I went with the 4" drop axle and need to order springs,,, I am building a moderately light teardrop,, I am hoping to come in around or under 700 lbs finished, dry,,, I am gonna be running 14" car tires and now the biggie question,,,, I can get 1000lbs/pair or 1500lb/pair springs,, what to do what to do????????? the 1500 springs are three leaf and I can always take out a leaf or just order the 2 leaf 1000 lb ones,,, I want it to ride as smooth as I can and it will be for highway use only,, no rock crawling or off roading,, should I adjust ride with air in the tires on 1500 lbs or hope the 1000 are enough,, suggestions from the masses please,,,,
just for info,,, sans tires and wheels,, the frame, tongue, coupler, axle, springs, brackets, and safety chain come in at 172 lbs, give or take a pound or so
thanks for the assistance
chipper
