Hardboard over 5mm ply
Postby ramtaajogi » Wed Jul 31, 2013 11:32 am
I was wondering if its a good idea to put hardboard over 5mm ply. I like the smooth white finish and need it to cover up a few small bumps I created when installing the inside roof skin.
While installing the inside skin, I heard some cracking of the 5mm ply and saw some crack lines on the outside. Once I had a few spars of screws in, the cracking stopped, but I was left with some small bumps/ bubbles.
I have it all glued nicely, but wondering if the cracking was a concern.
Thanks
ramtaajogi
Re: Hardboard over 5mm ply
Postby RandyG » Wed Jul 31, 2013 2:04 pm
Did you pilot drill before screwing? Could have been the spars splitting from the screws.
Randy
RandyG
Images: 115
Postby ramtaajogi » Thu Aug 01, 2013 10:50 am
I am sure it was the ply and not the spars. I can see small cracks in the ply. I just stapled the hardboard over the ply and it looks great, just hope it holds up. If not, I can easily remove it and replace.
ramtaajogi
Postby absolutsnwbrdr » Thu Aug 01, 2013 2:04 pm
Hardboard... Masonite? If any water gets into that stuff it just swells up and falls apart. :shock:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
