TEARDROP WINDOWS
TEARDROP WINDOWS
Postby MontanaTeardrops » Tue Sep 03, 2013 9:26 am
Can someone steer me to a source for teardrop windows? They don't have much on Ebay for them. Also, which is the best Fantastic Fan and a source with a good price?
MontanaTeardrops
Re: TEARDROP WINDOWS
Postby Esteban » Tue Sep 03, 2013 11:37 am
http://teardroptrailerparts.com/Windows___Doors.html Vintage Technologies by Frank Bear has windows, doors and much more. Frank can customize window and door trim rings to fit your doors or walls thickness, too.
http://www.lilbear.teardrops.net/index.html Lil' Bear by Grant Whipp has windows and much more.
These two are probably the premier teardrop specific parts suppliers.
For a Fantastic Fan http://www.rvvent.com/ Adohen Supply is top notch because they will customize one for you, which few others can or will do, at a fair price. After you order they most likely will call you to confirm your order and customization choices...which gives you a further opportunity to choose a Fantastic Fan that works best for your needs & budget. They're helpful and knowledgeable on the phone.
http://www.rvvent.com/5000rbt.htm The 5000rbt with a thermostat and a fan reverse switch is a good choice.
If you encounter rain a lot you might upgrade to http://www.rvvent.com/6000rbta.htm the 6000rbta which adds a rain sensor that closes the dome when it rains.
They sell every Fantastic Fan model. Some for le$$, some for more.
Their "No Choice" Fantastic Fans sell for a bit less than customized ones.
Here are the fields for your choices from their cart:
Item Number: 5000rbt (for example)
Item Name: Fantastic Vent 5000rbt
Dome Color : white, smoked, or clear
Dome Style : standard (taller and more curvy) or flat
Interior Color : white, off-white, or gray
Roof to Ceiling Thickness
Special Applications :
Type of Base? : High or Low profile
Actual Thickness: you tell them how thick your roof is and they will cut the interior trim so its right height for you
(A low profile base with a flat dome will stick up the least above the roof)
They will special order a double insulated dome if you want.
I am not sure if the new "pop n lock" easily removable screen is included on all new orders, or not. It may be. It might be good to ask when they call. Wish it was clearer on their website. Maybe if you order from them, when they call you, you could suggest they make it explicit on their website if the new "pop n lock" screens are included with their Fantastic Fans, at no extra cost?
Steve - SLO, CA
Esteban
Images: 15
Postby _Ryan_ » Tue Sep 03, 2013 4:49 pm
Esteban wrote:http://teardroptrailerparts.com/Windows___Doors.html Vintage Technologies by Frank Bear has windows, doors and much more. Frank can customize window and door trim rings to fit your doors or walls thickness, too.
Actual Thickness: you tell them exactly what you want and they will cut it for you
This is all great info here! I have personally talked with the Fantastic Fan manufacturer and http://rvvent.com is the only place to get customized fan vent. Their prices with customization and shipping are almost always less or on par than the competition (and they don't offer custimization).
Also check out http://www.auctiva.com/stores/viewstore2.aspx?id=1640272&styleid=12. They sell dozens of RV windows through their store front on ebay. Make sure the trim ring fits the thickness of your wall before you order, you can usually get away with 1/8" thinner or thicker. I bought my skylight from them and I couldn't be happier.
Good luck,
Ryan
_Ryan_
Images: 356
Postby razorback » Tue Sep 03, 2013 6:32 pm
I bought my windows, fantastic fan, hurricane hinge, and different seals from Grant.
He knows more about teardrops that most other companies.
He was patient with me and asked me a lot of questions to make sure I got exactly what I needed. He thought of many things I would never have thought to ask.
Never had the chance to meet him personally but I sure hope to at the next Pamplin Grove.
Larry
razorback
Re: TEARDROP WINDOWS, Fenders too
Postby Esteban » Tue Sep 03, 2013 7:37 pm
Since my above post helped I've dug up a few more:
KMTParts.com http://kmtparts.com/catalogsearch/result/?q=window&x=11&y=4 sells a 24" wide x 12" tall slider window.
They also sell customized teardrop trailer doors in different sizes and colors. The website does not list the prices for their doors. If they might interest you their phone number is 315-697-2441. Their website has the doors and window(s) under the "Trailer Body Parts" category
I bought windows and fenders from them (KMTParts). Was pleased with both. Found them by searching for 10.75" wide fenders which at the time were hard to find.
Getting a little afield from your original question if you might want aluminum fenders Frank Bear http://teardroptrailerparts.com/Teardrop_Accessories.html has them in one size. 10.75" w x 33" long (front to back) x 16.5" tall
Recstuff.com http://recstuff.com/singleaxletrailerfenders.aspx has a good choice of steel and aluminum fenders.
:) It's kind of fun to share sources of teardrop parts from my scores of saved "favorites" collected over the years.
Steve - SLO, CA
Esteban
Images: 15
Postby _Ryan_ » Tue Sep 03, 2013 7:42 pm
Esteban wrote:Since my above post helped I've dug up a few more:
This is HUGE, up until now only Frank Bear at Vintage Technologies had manufactured doors for sale! These are aluminum and a different style, it looks like they install from the outside and don't have trim rings. I dug deeper and found the prices, a bit more than Frank's if you want a window.
up to 45x26 NO WINDOW +$252.00
up to 45x26 With WNDOW 15x24 vertical slide with screen +$357.00
_Ryan_
Images: 356
Postby Esteban » Tue Sep 03, 2013 8:25 pm
Ryan: This is HUGE, up until now only Frank Bear at Vintage Technologies had manufactured doors for sale! These are aluminum and a different style, it looks like they install from the outside and don't have trim rings. I dug deeper and found the prices, a bit more than Frank's if you want a window.
Glad the KMT teardrop trailer doors fit your need/interest so well. I added links to them on a whim. Your research on their prices and sizes helps anyone who may read this. I wonder if they might be better thermally and sound insulated than Frank Bear's door(s) which are all glass and aluminum? They (KMT doors) might have more visual privacy, too...with less glass area.
GoLittleGuy.com http://www.golittleguy.com/teardrops/store/product/replacement-doors sells "replacement" teardrop trailer doors too for $295 + $110 for shipping and crating. Their two sizes are 26" wide by 32" tall or 26" wide by 36" tall.
I've seen some others selling teardrop trailer doors on EBAY from time to time. They seemed to be surplus ones.
Steve - SLO, CA
Esteban
Images: 15
Re: TEARDROP WINDOWS & DOORS
Postby Esteban » Tue Sep 03, 2013 9:17 pm
:pictures: KMTParts.com K805 Teardrop Trailer Doors : http://kmtparts.com/k805-teardrop-trailer-doors.html
TEARDROP TRAILER DOORS
These are very high quality doors specifically designed for use in the smaller tear drop type trailers. They are available with or without windows. They are insulated and have 4 radius corners. They are 1 1/4" thick and surface mount.
They come in many colors. You provide the hole and we fill it with a nice door. Like plug and play type installation. The following 2 doors are pretty common. If you require a special size to make your trailer that something special, just call. 4-corner radius K805 series 32x26 and a 36x28. The window is a 15x24 vertical slide. Door has flush latch with key lock.
These are shipped in plywood boxes to protect them. As always, we will combine shipping for multiple quantities. Small doors will go UPS, larger ones will go truck freight. either way you must call for freight quote. 315-697-2441
TEARDROP TRAILER DOORS *
up to 45x26 With WINDOW 15x24 vertical slide with screen +$357.00
(bold added)
I missed reading, at first, that the doors are insulated. Good. From the photo it looks like they have a flush mount Trimark (style) door lock. Trimark locks have dead bolts. I also see that, as Ryan mentioned, the mounting trim ring would be screwed on from the outside. Above, it says the doors are 1 1/4" thick which can work well for insulated walls. The features of KMT's K805 doors seem like a good, though pricy, choice for a teardrop trailer door. They'd be a big construction time saver, probably an ooopsie saver too, with good features not available from other door suppliers.
(added) The ebay listing, below, tells what colors are available.
So, I wonder who has used them and can give us real life feedback?
Steve - SLO, CA
Esteban
Images: 15
Postby Esteban » Tue Sep 03, 2013 9:29 pm
KMT's ebay listing http://www.ebay.com/itm/111010491762?item=111010491762&viewitem=&category=50069&vxp=mtr for KMT's K805 teardrop trailer doors.
$399.95 each with free shipping.
K805 TEARDROP CAMPER TRAILER DOOR. door/window 32x26, key lock, 15x24 window/screen these are VERY high quality made doors!
available in many colors, 3-4 week lead time. ship from Indiana UPS. Passenger side or drivers side. You must tell us which side. Same price.
These doors are pre-hung in an aluminum frame. Continuous hinged, left or right side. The window slides open and has a screen. A larger size,
36x28 is also available. These are built to order one at a time. So they are not mass produced.
YOU MUST TELL US THROUGH EMAIL, OR PHONE CALL THE FOLLOWING
DOOR TO BE MOUNTED ON PASSENGER OR DRIVERS SIDE OF YOUR TRAILER.
WHAT COLOR DO YOU WANT THE EXTERIOR SKIN? SOME OF THE COLORS WE HAVE ARE, WHITE, BLACK, PEWTER, CHARCOAL, YELLOW, GREEN, RED BLUE AND A FEW OTHERS,
IF YOU DO NOT CONTACT US YOU WILL GET A DRIVERS SIDE MOUNT DOOR IN PEWTER COLOR. NO REFUNDS
Vintage Technologies, Frank Bear http://www.ebay.com/itm/RV-Teardrop-Trailer-New-Generation-Foam-Core-Insulated-Door-26-x-36-Drivers-/380699466043 has a second style door the "RV Teardrop Trailer New Generation Foam Core Insulated Door 26" x 36" for $299.95" It is similar to the KMT K805 door. It is shown with black trim. The windows are vertical sliders. Can come in colors of your choice inside and out. The lock looks like a Trimark style. Standard trim rings fit 3/4" walls, other sizes up to 2- 7/8"are available at extra cost.
There is getting to be a wider choice of manufactured teardrop trailer doors.
Two more teardrop doors from seller jdantiqu on ebay:
http://www.ebay.com/itm/Teardrop-Radius-RV-Trailer-Door-Window-Pair-26-x-36-/300949782126 RV Teardrop Trailer Door & Window Radius Pair 26" x 36" $600 for a pair. Black colored door with large vertical sliding window. Trimark style locks. Looks similar to the black aluminum and glass Vintage Technology doors.
http://www.ebay.com/itm/RV-Teardrop-Trailer-Door-Window-Radius-Pair-26-x-36-/300949782123 Teardrop Radius RV Trailer Door & Window Pair 26" x 36" $600 for a pair. Silver/aluminum colored door frame and outer skin with a smaller sized vertical sliding window than the one above. Trimark style locks. Looks like a good door for an aluminum sided teardrop trailer.
Steve - SLO, CA
Esteban
Images: 15
Postby MontanaTeardrops » Wed Sep 04, 2013 6:52 pm
I don't understand why I don't get email notifications when someone replies here. I have the box checked below for "Notify me when reply is posted"
Any way, Wow, thanks for all the suggestions. I have my doors cut out, but haven't started making the doors yet. I'm leaning towards just buying nice doors and save a ton of work, Do most of them work on 3/4" walls?
MontanaTeardrops
Postby grant whipp » Wed Sep 04, 2013 11:36 pm
Depending on the shape you want, building your own doors is really not that difficult, and can save you $100 to $200 over the cost of pre-built. I've got the hinges, moldings, latches & handles, seals, and even the windows ... and I'd be happy to send you some guide drawings & photos that will help you along the way! Let me know if I can be of assistance - http://www.LilBear.teardrops.net - [email protected]
Good Luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
