TEARDROP WINDOWS
Can someone steer me to a source for teardrop windows? They don't have much on Ebay for them. Also, which is the best Fantastic Fan and a source with a good price?
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
Esteban wrote:http://teardroptrailerparts.com/Windows___Doors.html Vintage Technologies by Frank Bear has windows, doors and much more. Frank can customize window and door trim rings to fit your doors or walls thickness, too.
http://www.lilbear.teardrops.net/index.html Lil' Bear by Grant Whipp has windows and much more.
These two are probably the premier teardrop specific parts suppliers.
For a Fantastic Fan http://www.rvvent.com/ Adohen Supply is top notch because they will customize one for you, which few others can or will do, at a fair price. After you order they most likely will call you to confirm your order and customization choices...which gives you a further opportunity to choose a Fantastic Fan that works best for your needs & budget. They're helpful and knowledgeable on the phone.
http://www.rvvent.com/5000rbt.htm The 5000rbt with a thermostat and a fan reverse switch is a good choice.
If you encounter rain a lot you might upgrade to http://www.rvvent.com/6000rbta.htm the 6000rbta which adds a rain sensor that closes the dome when it rains.
They sell every Fantastic Fan model. Some for le$$, some for more.
Their "No Choice" Fantastic Fans sell for a bit less than customized ones.
Here are the fields for your choices from their cart:
Item Number: 5000rbt (for example)
Item Name: Fantastic Vent 5000rbt
Dome Color : white, smoked, or clear
Dome Style : standard (taller and more curvy) or flat
Interior Color : white, off-white, or gray
Roof to Ceiling Thickness
Special Applications :
Type of Base? : High or Low profile
Actual Thickness: you tell them exactly what you want and they will cut it for you
(A low profile base with a flat dome will stick up the least above the roof)
They will special order a double insulated dome if you want.
I am not sure if the new "pop n lock" easily removable screen is included on all new orders, or not. It may be. It might be good to ask when they call. Wish it was clearer on their website. Maybe if you order from them, when they call you, you could suggest they make it explicit on their website if the new "pop n lock" screens are included with their Fantastic Fans, at no extra cost?
Esteban wrote:Since my above post helped I've dug up a few more:
KMTParts.com http://kmtparts.com/catalogsearch/result/?q=window&x=11&y=4 sells a 24" wide x 12" tall slider window.
They also sell customized teardrop trailer doors in different sizes and colors. The website does not list the prices for their doors.
Ryan: This is HUGE, up until now only Frank Bear at Vintage Technologies had manufactured doors for sale! These are aluminum and a different style, it looks like they install from the outside and don't have trim rings. I dug deeper and found the prices, a bit more than Frank's if you want a window.
(bold added)TEARDROP TRAILER DOORS
These are very high quality doors specifically designed for use in the smaller tear drop type trailers. They are available with or without windows. They are insulated and have 4 radius corners. They are 1 1/4" thick and surface mount.
They come in many colors. You provide the hole and we fill it with a nice door. Like plug and play type installation. The following 2 doors are pretty common. If you require a special size to make your trailer that something special, just call. 4-corner radius K805 series 32x26 and a 36x28. The window is a 15x24 vertical slide. Door has flush latch with key lock.
These are shipped in plywood boxes to protect them. As always, we will combine shipping for multiple quantities. Small doors will go UPS, larger ones will go truck freight. either way you must call for freight quote. 315-697-2441
TEARDROP TRAILER DOORS *
up to 45x26 NO WINDOW +$252.00
up to 45x26 With WINDOW 15x24 vertical slide with screen +$357.00
K805 TEARDROP CAMPER TRAILER DOOR. door/window 32x26, key lock, 15x24 window/screen these are VERY high quality made doors!
available in many colors, 3-4 week lead time. ship from Indiana UPS. Passenger side or drivers side. You must tell us which side. Same price.
These doors are pre-hung in an aluminum frame. Continuous hinged, left or right side. The window slides open and has a screen. A larger size,
36x28 is also available. These are built to order one at a time. So they are not mass produced.
YOU MUST TELL US THROUGH EMAIL, OR PHONE CALL THE FOLLOWING
DOOR TO BE MOUNTED ON PASSENGER OR DRIVERS SIDE OF YOUR TRAILER.
WHAT COLOR DO YOU WANT THE EXTERIOR SKIN? SOME OF THE COLORS WE HAVE ARE, WHITE, BLACK, PEWTER, CHARCOAL, YELLOW, GREEN, RED BLUE AND A FEW OTHERS,
IF YOU DO NOT CONTACT US YOU WILL GET A DRIVERS SIDE MOUNT DOOR IN PEWTER COLOR. NO REFUNDS
