Weatherstrip info, please
Postby eggsalad » Wed Sep 04, 2013 7:59 pm
My build will feature a salvaged door from a pickup cap/camper shell. It's hard to describe, but you'll see it in my upcoming build thread.
Anyhow, the door is framed on 3 sides with 1" x 1" aluminum angle, facing outward. This forms a flange/seal. The trailer wall into which this door will be set is painted plywood.
I need a source of peel 'n' stick weatherstripping, with a D-profile, that is fairly thin when compressed.
Thanks in advance,
eggsalad.
eggsalad
Re: Weatherstrip info, please
Postby Treeview » Wed Sep 04, 2013 10:08 pm
McMaster-Carr is an easy source.
Treeview
Images: 30
Postby Chuckles » Wed Sep 04, 2013 11:10 pm
my local Menards caries D-profile weatherstrip in a few widths and thicknesses. The stuff has wicked good adhesive too! I thought I would just peel it off my hatch when I needed to add more epoxy but I was not so lucky. Thinner didn't soften it neither did goof-off or caulk remover. I basically had to scrape it off with a sharp chisel then sand the remaining adhesive off.
Chuckles
Images: 48
Postby grant whipp » Wed Sep 04, 2013 11:30 pm
I've got a couple that might work for you - http://www.lilbear.teardrops.net/parts.html#seals
Let me know if I can help ... [email protected]
Good Luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby eggsalad » Thu Sep 05, 2013 12:34 am
grant whipp wrote:I've got a couple that might work for you - http://www.lilbear.teardrops.net/parts.html#seals
CHEERS!
Thanks, Grant! Can you tell me... the stuff you sell as "Door Seal"... it's about 3/8" high when uncompressed... but how much does it squish down to when compressed?
Appreciate it,
eggsalad
eggsalad
Postby grant whipp » Thu Sep 05, 2013 11:02 am
eggsalad wrote:Thanks, Grant! Can you tell me... the stuff you sell as "Door Seal"... it's about 3/8" high when uncompressed... but how much does it squish down to when compressed?
Appreciate it,
eggsalad
It compresses to almost nothing, about 1/16" or less ... it's a little "stiff" to begin with, but once it gets broken in it'll squeeze right down.
Let me know if there is anything else I can help you with. As always ...
CHEERS!
grant whipp
Images: 117
