More Choices for Manufactured Teardrop Door(s)
The availability of teardrop trailer doors has increased. Here's a helpful list of suppliers and sellers of manufactured (pre-made) teardrop trailer doors for people who may prefer to buy a door, or a pair of doors, rather than make their own.
There are more pre-made teardrop trailer doors available than most of us knew. Teardrop doors come in a range of prices, sizes, styles, shapes, window types, finishes and colors. Insulated teardrop doors are now available. Some doors can be customized with custom sized trim rings, different door panel colors or finishes, or may be built in custom sizes. Manufactured doors can be big time savers for anyone building a teardrop trailer.
Hope this information makes it easier for you to find the manufactured teardrop trailer door(s) that may best fit your wants, needs and budget. Sometimes sellers offer more, or different, door choices available from their Home Page than what they may offer on ebay. It may be good to look at both.
If you bought or are using one or a pair of these teardrop doors please share your experience with them. How much time and effort did it take to install the doors? How well does the quality and usability of the doors meet your expectations? How good was the service from the seller? Do you have any tips, or blunders, to share? Pictures of your doors and your camper are highly encouraged. If you know of any other good manufactured teardrop trailer doors, and where to buy them, please share that information too.
Working on it shares a tip for choosing a manufactured teardrop trailer door:
Disclaimer, many of these teardrop doors and suppliers were found on the internet. I do not vouch for them. Please do your own research before buying.
Vintage Technologies by Frank Bear TeardropTraileerParts.com has several styles of teardrop doors, in two heights, to choose from. One door style has a large window area. The New Generation door style is insulated with an inset vertical sliding window. His website has many other parts useful for building a teardrop trailer.
Doors and windows The doors are available in two sizes, 26" wide x 32" tall, or 26" wide x 36" tall. The standard trim ring fits 3/4" thick walls. There are no screws on the outside of the trim ring and custom trim rings are available at extra cost to fit walls up to 2-1/4" thick, or up to 2-7/8" thick for New Generations doors. New Generation doors come standard with mill finish panels...the panels can be customized in a selection of colors and finishes.
Vintage Technologies also sells the door(s) on ebay:
http://www.ebay.com/itm/RV-Teardrop-Passenger-Side-Trailer-Door-NEW-26-x-32-/261038448075?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item3cc71a9dcb If you want a 36" tall door you may need to call Vintage to order it.
Vintage Technologies New Generation insulated doors http://www.ebay.com/itm/RV-Teardrop-Trailer-New-Generation-Foam-Core-Insulated-Door-26-x-32-Passengers-/380712264826?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item58a438247 If you want a 36" tall door you may need to call Vintage to order it.
GoLittleGuy http://www.golittleguy.com/ a teardrop trailer manufacturer, sells two sizes of replacement doors. Their shorter door is 26" wide x 32" tall. Their taller door is 26" wide x 36" tall.
http://www.golittleguy.com/teardrops/store/product/replacement-doors
KMT Service Parts http://kmtparts.com/k805-teardrop-trailer-doors.html sells k805 insulated doors in two standard sizes. KMT can also make teardrop doors in custom sizes and colors.
Big Woody Campers http://www.bigwoodycampers.com/ builds teardrop trailers and sells parts for them including teardrop doors
http://www.bigwoodycampers.com/index.php/parts-and-accessories/prefab-camper-doors/prefab-camper-doors-detail
Woodland Trailer Factory http://www.woodlandtrailerfactory.com/ builds teardrop trailers and sells insulated teardrop doors
http://www.shop.woodlandtrailerfactory.com/TEARDROP-DOORS-26X32BLK.htm
ebay http://www.ebay.com/itm/TEARDROP-TRAILER-DOOR-RV-WINDOW-26-X-32-/230870906044#vi-content
Silver Tears Campers http://silvertearscampers.com/ builds teardrop trailers and sells three different styles of teardrop trailer doors.
http://silvertearscampers.com/parts/parts.html
A rectangular door that is shown in their parts page above.
Tri State Surplus sells a very large teardrop trailer door. http://www.ebay.com/itm/New-Rv-Trailer-Teardrop-Entry-Entrance-Door-43-x-43-/370872057722
A hat tip to Grant Whipp
My interest in manufactured doors increased because the doors I built didn't work out well. They didn't fit quite right and warped. They most likely warped because the wood for the inner 3/4" thick popular frame was still a little too green/damp (big box store uses swamp coolers) and because I leaned the almost finished doors against my workbench. I had fiberglassed the outside 1/4" plywood so it became stronger and more moisture resistant than the thin inside 1/8" plywood. As the door dried out over several months it warped/cupped a little too much to be usable. I could not straighten them.
With the cost of the windows, trim rings, locks, hinges, weather seals, wood, plywood, screws, staples, glue, primer, paint, varnish, epoxy,, fiberglass, sandpaper, other supplies, and tools (wore out a sander) and a value for my time (I spent well over a month, maybe two months, making 2 doors) I spent close to the cost of a pair of good manufactured doors.
Buying manufactured teardrop door(s) now that there are more of them to choose from may be an increasingly good choice (for some people) to save time (and frustration), maybe save some money, to get a quality door or two.
http://www.tnttt.com/viewtopic.php?f=21&t=57301 The "window in the door" is more likely to be an insulated door too.working on it wrote:
"The manufactured doors come in two basic designs: one is window as a door, and the second is window in the door. Again, if I had seen the second design, I might've bought one."
New 26" x 32" Teardrop Passenger's Side Traditional Trailer Door Tinted Glass With Radius Corners & Black Frame
He offers 19 aluminum siding colors. Siding and Roof Aluminum 9/27/2013 Update: I called Frank, he said the doors can come in the same finishes and colors as his siding, at no extra cost. Mill finish panels are standard. He said the doors have the same, no outside screws required, trim rings as his other door. The door is 1-1/2" thick.New Generation Foam Core Insulated 26" x 32" Teardrop Trailer Door With Tinted High Quality 15" x 24" RV Window With Radius Corners Mill Finnish Panel with Black Trim
KMT ebay shop for doors http://www.ebay.com/itm/111010491762?item=111010491762&viewitem=&category=50069&vxp=mtrThe doors are available with or without a window. They are insulated and have 4 radius corners. They are 1 1/4" thick and surface mount. They come in many colors. You provide the hole and we fill it with a nice door. Like plug and play type installation. The following 2 doors are pretty common. If you require a special size to make your trailer that something special, just call. 4-corner radius K805 series 32x26 and a 36x28. The window is a 15x24 vertical slide. Door has flush latch with key lock.
K805 TEARDROP CAMPER TRAILER DOOR. door/window 32x26, key lock, 15x24 window/screen these are VERY high quality made doors!
available in many colors, 3-4 week lead time. ship from Indiana UPS. Passenger side or drivers side. You must tell us which side. Same price.
These doors are pre-hung in an aluminum frame. Continuous hinged, left or right side. The window slides open and has a screen. A larger size, 36x28 is also available. These are built to order one at a time. So they are not mass produced.
YOU MUST TELL US THROUGH EMAIL, OR PHONE CALL THE FOLLOWING DOOR TO BE MOUNTED ON PASSENGER OR DRIVERS SIDE OF YOUR TRAILER.
WHAT COLOR DO YOU WANT THE EXTERIOR SKIN? SOME OF THE COLORS WE HAVE ARE, WHITE, BLACK, PEWTER, CHARCOAL, YELLOW, GREEN, RED BLUE AND A FEW OTHERS, IF YOU DO NOT CONTACT US YOU WILL GET A DRIVERS SIDE MOUNT DOOR IN PEWTER COLOR. NO REFUNDS
BLACK ALUMINUM EXTERIOR. BLACK INTERIOR PANEL. DOUBLE SAFETY LOCK WITH DEADBOLT ON INSIDE. KEYED ALIKE FOR RIGHT HAND AND LEFT HAND INSTALLATION. VERTICAL OPENING TINTED WINDOW WITH SLIDING SCREEN. 1-1/4" THICK, FULLY INSULATED COMPOSITE CONSTUCTION. COMES COMPLETE WITH HINGE, FULLY FRAMED AND WEATHERSTRIPPED. COMPLETELY WATERTITE. WHITE INTERIOR PANELS AVAILABLE ON REQUEST. PLEASE SPECIFY RH OR LH MOUNTING.
Teardrop Mitered Trailer Door & Window Unit. These Teardrop doors have double hung windows with a screen, mitered corners, and are colored mill finish aluminum. This door measures 26" by 36" and is 1 1/4" thick. It has locks with 2 keys for each door. Includes mill finish mounting trim.
New Rv Trailer Teardrop Entrance Entry Door.
New but may have some minor scratches or dings.
Made for teardrop trailers
Black aluminum frame, lock with keys and window
Cutout Size is 43" x 43"
Overall it is 45 1/2" x 45" tall and approx 2 1/4" thick
Radius Corner, Fiberglass with Aluminum Frame
Tan Color
grant whipp
Depending on the shape you want, building your own doors is really not that difficult, and can save you $100 to $200 over the cost of pre-built. I've got the hinges, moldings, latches & handles, seals, and even the windows ... and I'd be happy to send you some guide drawings & photos that will help you along the way! Let me know if I can be of assistance - http://www.LilBear.teardrops.net - [email protected]
Good Luck, and as always ...CHEERS!
