dpjeansonne wrote:I once saw a build with hollow insulated walls but can't find it again. Can you point me to a build with walls constructed of 3/4" plywood with cutouts for rigid insulation?
If insulation is not a requirement, would you still hollow out for reducing weight or just go with solid walls? I think I will still want a 1/8" skin on one or both sides.
I'm a huge advocate & pioneer (in recent times, anyway ...
...) of the "hollow insulated walls made from plywood core" build technique. Weight savings are substantial, and the insulative value gained is decent enough, even if you don't put insulation in (any dead air space has an insulative value). However, may I suggest that you start with a 1/2" core plywood with 1/8" on the inside and 1/4" on the outside (especially if you plan to skin the trailer with aluminum)? I think you'll find that the end result will be more than strong enough, light enough, moldings for around the doors and galley walls will be easier to find, and you won't loose that little extra bit of interior width.
If I can be of any help with advice or otherwise, please don't hesitate to ask. Good Luck on your build, and as always ...
CHEERS!
