Tommy2tone_1999 wrote:Thanks Randy!
Les, did you round your corners on the edges to get the fiberglass tape to lay down? If not, how did you stop the wetted tape from popping up on the edge?
I had 1/4" skins on top and both ends (including hatch) and 3/4" sidewalls. I cut my 1/4" skins pretty close to exact width (60") and then used a belt sander to knock down the square corners (some people cut them long and use a router). I then used an orbital sander to "sculpt" the radius to make it smoother. I'm guessing I had at least a 1/2" radius. It didn't have to be perfect because I covered it with aluminum edge trim after glassing and painting. I had no trouble wetting down the fiberglass tape. I did not soak the tape in the epoxy first like some do. I just laid it dry and wetted it thoroughly with chip brushes. It's been on there a year and we've camped in it numerous times and no cracking or damage of any kind to the paint.
